In this age of Google, I can't believe I'm having such trouble finding a two way threaded insert to put a glass knob on an emergency brake extension.
I need one that is 5/8" 18 pitch OD and 5/16" 24 pitch ID. I've tried so many search word combos, but all that comes up are metric pieces. Does anyone have a source for these? Thanks, Tim |
Why don't you take a 5/8"x18 bolt and slice off a piece and drill and tap it for 5/16"x24?
Tim,speeddawg.com or speed dawg shift knobs. iv'e recently replaced the original brown v8 ebossed shift knob in my '37 fordor cause the original knob way to small for my hand and dont car for shape of it either. imo the price was right i believe all the choices have a same size insert and you specify which insert you need.also geta washer which i did not use and a jam nut. Tom.
Tim,speedawg.com or speedawg shift knobs.all knobs come with a common threaded insert permanately installed and you coose the adapter size you need i too chose the 5/16"x24 for my '37. orig brown v8 embossed was way to small for my hand and didnt care for shape either Tom.
I've had good luck putting a helicoil in the shift knob also.
Thanks for all the suggestions. Hard to believe this is such a difficult item to source. I seem to recall these were fairly common items.
There on Ebay. Search, brass shift knob insert. Can get six different styles and metric or 5/8.
For some reason the knob peddlers all want to force the use of communist threads!
I have gotten this type of insert at Fastenal (sp?). I don't remember the exact dimensions I used buy they had a selection to choose from.
#13 |
Found one on Ebay. For the $10, it wasn't worth my time to make it at this point. Maybe when I retire I'll make a run of them.
#14 |
#15 |
#16 |
First part I ever made on a lathe was an insert to put a larger thread shift knob onto a Hurst shifter…..
#17 |
IIRC, JC Whitney's shift knob bushing increased your mileage by 15%. Not sure if anybody elses's version topped that, but it's unlikely.....
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#18 |
#19 |
Plate it & make it even faster!
#20 |
Put some grease on the thread of shift leaver,then fill the knob with JB weld and bingo .
