Old 03-09-2024, 07:48 PM   #1
PaulBob
Default Electric Fuel Shut off
I haven't made up my mind about adding an Electric Fuel Shut off to my 31 Coupe. Anyone have experience with them? Thanks.
PaulBob is offline   Reply With Quote
Old 03-09-2024, 08:07 PM   #2
Marshall V. Daut
Default Re: Electric Fuel Shut off
If your car has the pop-out ignition switch, you can't install the electronic shut off valve to be operated by the switch. You'd have to possibly run wires to a toggle switch.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 03-09-2024, 08:08 PM   #3
PaulBob
No pop out ignition switch. Would the electric switch do a good job?
Old 03-09-2024, 08:14 PM   #4
kenparker0703
Do not wire an electric fuel switch on same switch if you have an electronic distributor. The electritikkles dont like one another. As marshall says use a separate switch.
I have used them on several cars. I like the ideaa. len
kenparker0703 is offline   Reply With Quote
Old 03-09-2024, 08:20 PM   #5
PaulBob
No electronic distributor. No leak problem using electronic fuel cutoff switches on several cars?
Old 03-09-2024, 08:26 PM   #6
CarlG
CarlG's Avatar
I've been using one for 10+ years with no problems.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-09-2024, 08:40 PM   #7
SDJason
SDJason's Avatar
My 1930 Town Sedan had one that was put in by a previous owner.
It worked fine for around 10 years, but then I found out the hard way that when one of those fails, it fails in the "Off" position - meaning that if you're driving along and it fails on you somewhere, you won't be getting the car home under its own power. I decided to replace it with a 1/4-turn ball valve.
SDJason is offline   Reply With Quote
Old 03-09-2024, 09:34 PM   #8
PaulBob
Are you happy with Ball type cutoff? No leaks?
Old 03-09-2024, 09:44 PM   #9
Bruce of MN
Bruce of MN's Avatar
Pardon my ignorance, but what other solenoid valve type is there?
Old 03-09-2024, 09:51 PM   #10
gdmn852
gdmn852's Avatar
Hello, I have one on my 31 , installed by previous owner, seems to work ok , does have separate shut off switch, also have a master switch on battery. Better than having to raze hood to use factory shut off.
gdmn852 is offline   Reply With Quote
Old 03-10-2024, 06:26 AM   #11
nkaminar
nkaminar's Avatar
I have an electric fuel pump for my Weber down draft. When off it will not allow fuel to flow. I carry extra fuel lines to use in case the fuel pump fails. I use the manual valve when I want to run the carburetor dry. But this discussion has given me the idea of removing the separate fuse for the pump instead, or adding a switch.
Old 03-10-2024, 07:46 AM   #12
oldspert
oldspert's Avatar
I put one on my 29 and because of the ethanol in todays fuel, the seal swelled so bad it shut off all of the orifice and would not pass enough gas (no pun intended) for the engine to run. I replaced it with a 1/4 turn ball valve also with no other problem.
Ed
oldspert is offline   Reply With Quote
Old 03-10-2024, 08:51 AM   #13
midgetracer
midgetracer's Avatar
I have the solenoid valves on both of my 31's and I love them. I have had them for about 10 years.
midgetracer is offline   Reply With Quote
Old 03-10-2024, 09:48 AM   #14
Big hammer
I’am for K.I.S.S. After going through my fuel system, pencil filter in the tank, lapping the gas valve, cleaning the carburetor float valve, I then had a leakless system. I would turn my car off and walk away, checking for leaks drips several times a day and for about 1 1/2 years no leaks or drips. Then after the car sat for a couple of weeks she began dripping from the carburetor, I would then close the shutoff valve and run the carburetor dry. Procrastinated that one day I need to address the float valve which I didn’t, I just started driving her more, after a couple weeks I started just walking away and behold she stopped dripping ! that’s been about a year. My guess the fuel flushed the junk away cleaning the float valve, Ford built a durable and simple car ! K.I.S.S.
get a bigger hammer tap done
Old 03-10-2024, 10:31 AM   #15
SDJason
SDJason's Avatar
Absolutely happy - it's been around 4.5 years, and still working fine.
Having to open the hood to turn it on/off doesn't bother me - just made it part of the routine (along with the battery cutoff switch) - it becomes a habit that you don't really think about.
Old 03-12-2024, 08:19 AM   #16
desotoguy
Can someone post a manufacturer and part number for the solenoid valve that you use? The valves I looked at had a time limit for being in the open position. TIA
desotoguy is offline   Reply With Quote
Old 03-12-2024, 12:44 PM   #17
Marshall V. Daut
Unfortunately, unless you still have an original on/off valve, you can't simply "lap" the stem on repo valves because of their construction. They either hold fuel back or leak and as far as i know, cannot be "rebuilt" with available kits. If someone has found a way to lap repo valve stems to seal again, I'd sure like to know about it. I have a half dozen leaking expensive repos that didn't last very long before they started leaking. And a couple were valves touted by the national vendor in his catalog as being high quality and leak-proof. Hmmmmm....
Marshall
Old 05-25-2024, 12:07 PM   #18
Zoltan
Zoltan's Avatar
I put one on my 31 coupe with great results. It works great with a modern (non pop-out) ignition switch using the accessory connection. I wanted to install it downstream of the sediment bulb. Plus, I'm too old and lazy to work under the dash.
Zoltan is offline   Reply With Quote
Old 05-26-2024, 06:44 AM   #19
nkaminar
nkaminar's Avatar
Zoltan, I like what you did to eliminate shorts behind the instrument panel.
Old 05-26-2024, 09:33 AM   #20
katy
katy's Avatar
If I was going to use the solenoid shut off valve I would put it under the dash, not in the engine compartment.
