Old 02-25-2024, 08:55 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Left Lights On By Mistake
After a run, I parked my Victoria in the driveway to let it cool off, but I forgot to turn the low beam halogen headlights off. The lights were on for several hours and the battery would not run the starter.
For your info, I found that using a charging rate of 12 Amps for 2 hours was enough to rejuvenate the 12V battery to start the car. However, the battery needs more charging to reach its full capacity.
Bob Bidonde
Old 02-25-2024, 11:31 AM   #2
ModelA29
ModelA29's Avatar
Default Re: Left Lights On By Mistake
Aren't you glad they came with a crank.......
ModelA29 is offline   Reply With Quote
Old 02-25-2024, 12:49 PM   #3
denis4x4
denis4x4's Avatar
I have these remote battery posts that make it easy to jumpstart or attach a battery tender.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 02-25-2024, 04:58 PM   #4
nkaminar
nkaminar's Avatar
If you get your friends to hand push the car at about 25 miles per hour, it will start in high gear.
OK, joke over. Now on to some serious stuff. Leaving the battery discharged or partially discharged will cause the usual amorphous lead sulfate to crystalize. The crystalized form cannot be used by the battery and the battery capacity is deminished. A desulfating battery maintainer will change the crystalized sulfate back to the amorphous form that can then be used by the battery. It will restore the battery capacity. The desulfating battery maintainer works by sending high frequency pulses through the battery.
Old 02-25-2024, 05:58 PM   #5
ndnchf
ndnchf's Avatar
Another good reason to change over to LED headlights
ndnchf is offline   Reply With Quote
Old 02-25-2024, 06:11 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
I left the ignition switch on and the battery sat totally dead for a while,
Because I have a diode cutout anything the generator made went into the electric system, could get 4 volts hand cranking, — vigorously hand cranking, it started, drove 45 minutes to car show, the battery started the car by the time I arrived at the show.
Everything stock in electrical system except for diode cutout.
I do run a 14 amp charge rate because of a lot of night driving and halogen headlights,
Old 02-25-2024, 06:17 PM   #7
Gene F
Gene F's Avatar
Actually if the car has been running that day, push start (BY A COUPLE GUYS) and drop the clutch with the key on in 2nd or 3rd gear does the trick easily, and really quick. I have actually done this catching a down hill grade by myself, and jump in to hit the gear and drop the clutch.
Old 02-25-2024, 06:46 PM   #8
Afordman31
Afordman31's Avatar
Where did you get the posts to make this setup?
Afordman31 is offline   Reply With Quote
Old 02-25-2024, 06:58 PM   #9
Keith True
Keith True's Avatar
You can find them on amazon.A lot of modern cars have them.I had them on a car that had the battery mounted down under the head light.I think it was a PT Cruiser.
Keith True is online now   Reply With Quote
Old 02-25-2024, 09:20 PM   #10
ModelA29
ModelA29's Avatar
Battery Tenders come with 2 options to connect them. The first is clips and the other has ring terminals that you can install so you can plug it in without removing the floor. My plug comes through the floorboard by the seat and is hidden under the mat when not in use.
Of course it's only good when parked in my garage. If it dies somewhere else I'll be pushing while the wife pops the clutch - in second.
Old 02-25-2024, 09:46 PM   #11
katy
katy's Avatar
12 amps for 2 hours is only 24 amp hours, if you have a 100 amp hour battery it will need at least 12 hours at 12 amps to bring it to near full charge.
katy is online now   Reply With Quote
Old 02-26-2024, 05:41 AM   #12
Bruce of MN
Bruce of MN's Avatar
I am in the habit of flipping the battery cutoff switch in front of the seat to off when I park. It covers up my possible multitude of sins.
Old 02-26-2024, 08:22 AM   #13
Bob Bidonde
Katy, you are correct. I still need to charge the battery more. I plan to do this by running the car around town, so the alternator can get the job done.
ModelA29, I have a tool box that blocks hand cranking.
Bob Bidonde
Old 02-26-2024, 08:32 AM   #14
denis4x4
denis4x4's Avatar
Speedway Motors and check out their bracket.
Old 02-26-2024, 05:28 PM   #15
Afordman31
Afordman31's Avatar
Thank you very much. Appreciate it!
Old 02-26-2024, 10:32 PM   #16
CarlG
CarlG's Avatar
I installed one of these when I had halogen headlights. Still works with LEDs.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-26-2024, 10:47 PM   #17
eagle
eagle's Avatar
An alternator will not deep charge a drained battery. Put it on a slow charger overnight or even 24 hours. Nothing like a slow, deep charge. 2 amp is perfect, preferably NOT a smart charger.
