Old 02-07-2024, 07:09 AM   #1
48fordconv
Default Lug nuts from Third Gen Auto
Has anyone bought lug nuts from them for 48 ford car. I can't seem to get hold of them. Do the threads start in a ways on the nuts or start at edge ? Thanks
Steve
48fordconv is offline   Reply With Quote
Old 02-07-2024, 07:59 AM   #2
corvette8n
corvette8n's Avatar
Default Re: Lug nuts from Third Gen Auto
I’ve bought some for my ‘41 at my local NAPA.
Old 02-07-2024, 11:57 AM   #3
J Franklin
J Franklin's Avatar
Yes, NAPA would be a good source.
Old 02-07-2024, 12:00 PM   #4
TJ
TJ's Avatar
Take an old one for a sample to Napa. These new counter guys don't have a clue when you ask for lug nuts for a '48 Ford.
Old 02-07-2024, 12:05 PM   #5
Ken/Alabama
Ken/Alabama's Avatar
Steve
I like the ones that have the threads recessed a little. Makes them a little easier to start.
Old 02-07-2024, 12:07 PM   #6
paul2748
paul2748's Avatar
most Ford lug nuts right from the early days were 1/2 fine thread. I have a s**t load of these. Should be able to get them any where.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 02-07-2024, 12:36 PM   #7
NealinCA
NealinCA's Avatar
I buy them at the local trailer supply. They have 5 gallon buckets full of 1/2-20 lug nuts
NealinCA is offline   Reply With Quote
Old 02-07-2024, 01:13 PM   #8
DavidG
DavidG's Avatar
The lug nuts from third gen work fine. They are recessed like the original, but still require a bit more trial and error before the threads catch. Using a thread chasers on the nuts and studs speeds up the process.
Old 02-07-2024, 01:24 PM   #9
48fordconv
Just what I was looking for at Third Gen Auto > Thanks for info will order right now.
Old 02-07-2024, 01:47 PM   #10
KiWinUS
KiWinUS's Avatar
Same experience as DavidG.
Old 02-07-2024, 09:31 PM   #11
cas3
Nuts that are threaded all the way thru will sometimes bottom out on the stud before the wheel is tight. I've run into that with cheap aftermarket stuff, its something to keep an eye on when mounting wheels.
Old 02-08-2024, 07:25 AM   #12
PeteVS
PeteVS's Avatar
The Ford nuts have a 13/16" hex, 1/2-20 thread and a 60º cone. There are lots of nuts around that don't have the hex size or cone angle right.
Old 02-09-2024, 02:02 PM   #13
B-O-B
B-O-B's Avatar
Dorman parts in any auto parts store .
B-O-B is offline   Reply With Quote
