Old 01-19-2024, 08:25 PM   #1
Klattu1929
Default Crank bearing plate
'29 Phaeton, engine # says built in April. My bearing plate has two nubs that should match two dimples in front crossmember. problem is the nubs are 2 3/4"
apart, and the dimples in crossmember are 2 1/2" apart. So the crank plate won't sit flat on crossmember. This is how I found it when I removed the front leaf spring(broken center leaf). Has anyone come across this?
I don't have dimensions for a 1930 and later bearing plate. My frame is a late 28 or early 29,
since it has the cutouts for the '28 brake system in the middle crossmember, (has the '29 brake system installed) but the frame serial # is corroded away. Les Andrews Red Book pg 278 shows I have the correct crank bearing plate plate for a '29. Any insight would be helpful, thanx. Or I may just make a new dimple in the crossmember, not preferred tho.
Klattu1929 is offline   Reply With Quote
Old 01-19-2024, 11:34 PM   #2
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
Default Re: Crank bearing plate
You would probably have better luck putting new dimples in the plate under the springs. Use a flat washer up from the bottom NOT the one one intended for the 28. Ford changed to the flat washer pretty early and continued to the end .
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 01-20-2024, 06:47 AM   #3
nkaminar
nkaminar's Avatar
I would grind the nubs off and then carefully align the plate when putting it back. The U bolts for the springs are plenty tight to hold the plate in place. That is what I did for my car anyway.
