Old 12-18-2023, 10:55 AM   #21
cadillac512
cadillac512's Avatar
Default Re: Vibration
Originally Posted by 47jailbar View Post
I doubt it’s wheel/tire related as there is no vibration at low speeds and seems to be more dependent on engine RPM; at shift points and above 45 mph in third. No tach installed at this time however by my calculations 275 60 15 tires with a 4:11 gear would produce a driveshaft rotation in the neighborhood of 2220 rpm at 45 mph which would also correspond to a reasonable shift point.
This is a clue. It appears the vibration may be engine, flywheel or clutch related since the above statement indicates it occurs both at shift points and above 45mph in third (which would be another shift point if there was another gear). This would likely rule out anything to the rear of the clutch.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 12-20-2023, 03:13 PM   #22
Scott52
Even if it is weeks or months down the road, please update your post with the solution you found.
Scott52 is offline   Reply With Quote
Old 02-10-2024, 09:38 PM   #23
ScubaChief60
ScubaChief60's Avatar
Curious here 47jailbar if you ever figured out the source of the vibration? Always like to know just in case it happens to me again down the road. Thank you!
ScubaChief60 is offline   Reply With Quote
