Old 12-01-2023, 01:52 PM   #1
Ol' Ron
Ol' Ron's Avatar
Default Shoud I relieve my block
The answer is: absolutely not!!!! The internet as posted several articles on relieving the flathead block. I did allot of this in the early days, untill I went racing, and discovered the fact that very few builders did this. In a conversation with a builder of a few good winning engines , stated there was no real information of the benefits of relieving the block and it was time consuming and a pain in the ass to install the pistons, PLUS no prof that it increased power or economy,
Gramps
Old 12-01-2023, 03:49 PM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Shoud I relieve my block
I would never do it based on the lower CR. Some folks get a big kick out of a relieved block. I had a relieved block and sold it. I was glad to see it go. I agree with you Ron.
Old 12-01-2023, 03:50 PM   #3
19Fordy
19Fordy's Avatar
It's a relief not to relieve.
Old 12-01-2023, 04:09 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
I must admit that I would never go to the expense in time or money of relieving a block. But with that being said, I've still gotta ask WHY did those Frenchmen go to the trouble on those beautiful French flatheads (one of which I just sold the last couple of days), as well as the relatively few that Henry Ford produced for buses and other industrial equipment?
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 12-01-2023, 05:17 PM   #5
Jack E/NJ
Jack E/NJ's Avatar
Some claim if the exhaust is left alone and the intake relieved a bit, good things might happen.
Old 12-01-2023, 06:04 PM   #6
Pete
I would not bother on a mild street engine but I can get well over 1 hp per cubic inch naturally aspirated on gas in a race engine.
The relief is as deep and wide as the block material will permit. The pistons are flat.
Old 12-01-2023, 06:48 PM   #7
cadillac512
cadillac512's Avatar
Is the head flat as well,Pete? Good compression.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 12-01-2023, 07:03 PM   #8
Ronnieroadster
Ronnieroadster's Avatar
Like Pete wrote for a mild street engine there's no need. However if your interested in getting some more power and economy taking the time to do it correctly is worth the effort. We know Ford did do it on engine's going into Ford trucks makes you wonder why. And as Coop points out the French flathead blocks all had the relief's. Plus as an added point of interest the one flathead design that produced a LOT of power and I would expect economy if needed was the Harley Davidson KR headed flatheads with a relief and that was in the 1960's era.
Like Pete wrote 1 HP per cubic inch out of a Ford flathead is easily possible its being done everyday.
The slight amount of compression reduction caused due to the block being relived in a flathead is actually a good thing considering the poor quality of the gas we have today. High compression and to much timing is a killer for a Flathead unless your burning a good quality high octane gas if your are than your good to go.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 12-01-2023, 08:29 PM   #9
Graeme / New Zealand
Graeme / New Zealand's Avatar
I have a 99A block sitting under a tarp that is factory relieved.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 12-01-2023, 11:08 PM   #10
Pete
The head is flat also. The transfer area in the head is adjusted for compression ratio.
I can get 14 to 1 compression ratio for running alcohol.
Old 12-01-2023, 11:35 PM   #11
Ol' Ron
Ol' Ron's Avatar
I've run some flow test on cumbustion chamber design, and as airflow speeds increas so does the turbulence caused by chamber irregularities. overt 4500 RPN The turblance increase dreamily and the valve bowl is the worst. One reason the torque drops after 4500 rpm. John and I talked about it when he as buildinng his Bvill engine and he came uo with the new guides which helped this area. Photos in his book. I'll post some computer flow graphs, but can't be sure of their accuracy
Gramps
Old 12-02-2023, 06:38 AM   #12
mcharley40
I’m no expert however I do have bunch of old literature from early days of Harley Davidson on their development of the side valves. All their successful racing engines had a relief area.
Hopping up Ford Flatties seem to follow suit. Ron you have real knowledge of real testing.
Good enough for me.
mcharley40 is offline   Reply With Quote
Old 12-02-2023, 10:44 AM   #13
Bored&Stroked
Bored&Stroked's Avatar
I have original Harley KR jugs and heads - they were relieved and also had a very different head design. They ran mostly flat-top pistons until later in the 60's when they tried a dome top. The dome top engines didn't make any more HP than the flat-topped piston designs. Of course, these were purpose built racing engines and ran way past 6000 RPM all the time. Flow was everything to their design, with huge ports, big valves, etc.. We only wish our Ford flatheads had anywhere near the type of ports and head-bolt layouts of the Harleys.
When I designed our FlatCAD chambers, heads and pistons (flathead Cadillac Bonneville engine) - we used as much of the 'KR' design as possible - including the custom mods that Jerry Branch made for his modified KR's.
Branch (and my neighbor 'Snuffy Smith') made some of the highest HP KR's of the day. I learned a LOT from Snuffy! Snuffy built a KR for use at Daytona for a rich guy back in the early 90's - was making about 60 HP on a 45 cube KR on gas. The guys running the dyno were really surprised about the HP he was able to achieve on the good ole' KR sidevalve motor.
Old 12-02-2023, 10:51 AM   #14
Bored&Stroked
Here is a picture of a KR head - for flat top pistons - the piston popped up about 3/16" of an inch into the chamber. This was very important for flow:
Here is a picture of the Navarro Hi-Flo head - which used some of the KR type design (stepped relief):
Here is a Tony Baron "Pop-UP" head - using a very tall pop-up piston design:
Here is a picture of the 3D CAD Model for the FlatCAD chambers:
Here is the actual FlatCAD Head Chamber:
Old 12-02-2023, 01:06 PM   #15
Ol' Ron
Ol' Ron's Avatar
Well I guess I'm wrong. I'd like to see a flathead that makes one HP per cubic inch flathead on gas. I nolonger have the eqipment I used for my testing, so I can't comment on these reselts with any acury. I agree with the HD engine design as we looked at it back then. The Grancore heads were similar with a pop up piston. someone out there has them, Ford factory relieved blocks didn't last long and were designed to limit detention. I was told. But they never included it in the late engines or the 337. The French were just copying it.
Everybody has an excuse for their actions and beliefs , I stand corrected.
Gramps
Old 12-02-2023, 02:39 PM   #16
Jack E/NJ
Jack E/NJ's Avatar
RR>>1 HP per cubic inch out of a Ford flathead is>>done everyday.>>
O'R>>Well I guess I'm wrong. I'd like to see a flathead that makes one HP per cubic inch flathead on gas. >>>
Maybe not Ol'Ron.. Prolly only done every other day.
Old 12-02-2023, 03:30 PM   #17
Pete
For those that keep saying they would like to see a flathead Ford race engine that makes over 1 hp per cubic inch naturally aspirated on gas, I would like to tell you how simple that is.
First off, you will see the engine and car but you will not see inside the engine. These engines are seldom torn down at the track unless it is for record certification and unless you are a VERY good friend of the owner, you are not going to see much.
To see one of these engines, you must first find out what cars they run in by looking up records set at the various tracks they run at. This is easily done by looking up land speed racing tracks in the USA. There are several beside Bonneville.
When you find where they are running you contact the car owner and find when he is going to run, Then you go watch.
These engines have been around since the 50's so they are really nothing new.
Old 12-02-2023, 08:00 PM   #18
Bored&Stroked
Gramps
Actually, you were not wrong - it is all about the application and usage of the engine. Relieving a Ford Flathead does nothing of value before about 4000 - 4500 RPM . . . actually it hurts low end power as it reduced compression (with everything else the same). Also, relieving is just one small piece of the overall puzzle - you have the ports to worry about (they take serious amounts of work), you have the cam to worry about, you have the valves, the chambers in the heads, etc.. As Pete noted - when all the things are specifically designed to work together (for racing) - then relieving is part of the "combo" that was typically used.
Also, typically these naturally aspirated engines were fuel injected - which surely adds horsepower over the typical Stromberg setup. And truth be told, the classical Hilborn flathead injector is too small for max HP. Guys like Don Ferguson Sr. cast their own injectors way back in the 80's - with big port/butterfly sizes more like a SBC injector (to get the flow they needed).
Then, one can start talking about oil-control, dry-sumps, crank scrapers, vacuum pumps, low-tension rings, straight-cut cam gears, etc.. A lot can go into one of these engines - and it is not for those "on the cheap".
Old 12-02-2023, 08:05 PM   #19
tubman
tubman's Avatar
Oh, so it's the old : "I could tell ya', but then I'd have to kill ya'".
Old 12-02-2023, 09:14 PM   #20
38 coupe
38 coupe's Avatar
I have the same understanding as Ron, the factory relief was an effort to limit detonation by lowering compression in truck engines, not an effort to improve power. Note that this method of lowering compression preserves the quench between the piston and head and doesn't suffer from the misery that was the 1970s attempts at the same thing by using dished pistons.
Ford flathead V8 chamber design is an interesting subject, and most of the top racing engine builders will not share what their development looks like. Kudos to Bored&Stroked for doing that.
I stumbled on another flathead Ford racing chamber design earlier this year while wandering around the Model T regions of the world wide web. Apparently one of the Kloth combustion chambers from the race motor in the celebrated 1950 Mercury sedan got used as the design for a new Model T high compression head. Link to the web page here: http://hcgarage.net/T-Head.htm
Picture of the combustion chamber, note the larger portion of the chamber is on the intake side:
