Old 11-29-2023, 12:53 AM   #21
cas3
Default Re: 6 Volt heater motor rebuild
Fred bought a lot of stuff at my auction. No heater motors though!
Old 05-03-2024, 07:23 AM   #22
Terry,OH
Terry,OH's Avatar
The logo pictured is not from a Hadees heater! They did have a logo which was a profile of the devils head.
To make a DC motor reverse rotation change voltage polarity on just the stator or just the rotor. Changing the polarity on both will result in no change of rotation. With the Ford original motor this was done through the switch.
Old 05-03-2024, 07:51 AM   #23
ndnchf
ndnchf's Avatar
I'm no expert on Hadees heaters, but I did restore one 6 or 7 years ago. Here are a couple other similar badges that say Hadees Heater on them.
ndnchf is offline   Reply With Quote
Old 05-03-2024, 08:12 AM   #24
kartrae7
kartrae7's Avatar
The easiest way i found to make this work. I used the two wire motor from napa, a 1941 switch with heat and defrost. Switch is marked with color dots from memory black is 6v, red and green are wires from motor, yellow is ground. The switch will change direction of the two wire leads to the motor giving you defrost and heat. Has to be run on 6v because the wire resistor will not live long on 12v. Mike
kartrae7 is offline   Reply With Quote
Old 05-03-2024, 10:53 AM   #25
petehoovie
petehoovie's Avatar
