Old 11-27-2023, 05:21 PM   #1
41 Ford PU
Default 6 Volt heater motor rebuild
I just went through a lot of search results looking for information regarding rebuilding of my 6 volt heater motor. Unfortunately, most of it was at least 10 years old and not all that current.
So, does anyone have or know of someone that will rebuild a 6 volt heater motor.
This is in a 41 Pickup. The wires are shot. Supposedly it ran when last checked, but I don't know how it was tested considering the condition of the frayed wiring.
I can take it apart if needed, but am not certain what I would need to do then.
Electric motors are not my strong suite.
The other option is if anyone has a good motor, I would/could buy it.
I'm still searching for other options.
41 Ford PU is offline   Reply With Quote
Old 11-27-2023, 05:56 PM   #2
ndnchf
ndnchf's Avatar
Default Re: 6 Volt heater motor rebuild
Look up NAPA #6551021. It is a universal, reversable 6v heater motor. I rebuilt the heater in my Willys jeep using one. It was not hard to adapt it. It worked great.
ndnchf is offline   Reply With Quote
Old 11-27-2023, 06:03 PM   #3
Bob from Northport
Bob from Northport's Avatar
I just tried searching that number on NAPA. No results on the web site. Any other information ndnchf???
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 11-27-2023, 06:09 PM   #4
ndnchf
ndnchf's Avatar
I searched and it came right up:
https://www.napaonline.com/en/p/BK_6551021
Old 11-27-2023, 06:12 PM   #5
OhioRick
OhioRick's Avatar
Here you go
OhioRick is offline   Reply With Quote
Old 11-27-2023, 07:12 PM   #6
petehoovie
petehoovie's Avatar
Blower Motor - AC / Heater
NAPA Part #: BK 6551021
Line: Balkamp
Price
$46.99
Old 11-27-2023, 07:28 PM   #7
ndnchf
ndnchf's Avatar
Here is the Hadees brand heater I restored 5 or 6 years ago using the NAPA motor. The new motor was a little longer than the original, but there was plenty of room for it. Their slogan was "hotter than Hell" and they had a rather naughty badge
Old 11-27-2023, 07:35 PM   #8
petehoovie
petehoovie's Avatar
Old 11-28-2023, 01:04 AM   #9
FortyNiner
FortyNiner's Avatar
So, how is this unit wired to the switch to make it reversing?
Old 11-28-2023, 04:35 AM   #10
big job
big job's Avatar
but it does not say if 6 or 12 volts? I need 6 volt....
big job is offline   Reply With Quote
Old 11-28-2023, 06:19 AM   #11
ndnchf
ndnchf's Avatar
To reverse direction of rotation, you simply swap the wires around. Odd that it does not say 6 volts, it used to. But it is the 6 volt version. The 12 volt version is part number 6551022.
Old 11-28-2023, 09:52 AM   #12
kirkf
kirkf's Avatar
The heater motor used in 1940 would have been a four wire model.
They used forward and reverse for different defrost modes.
To make the NAPA motor work you would have to implement relays to reverse the polarity from the switch, to achieve the same results.
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
kirkf is offline   Reply With Quote
Old 11-28-2023, 10:17 AM   #13
cas3
I've had several Hadees heaters and not seen that badge before. Mine have just the devil with some flames in back of him ( or her...we must be politically correct now days ) , I like yours better!
Old 11-28-2023, 11:01 AM   #14
V8 Bob
V8 Bob's Avatar
Kirk
I use a simple polarity-reversing toggle switch with the 6551022 motor in my '40s Ford heater.
Old 11-28-2023, 11:15 AM   #15
Seth Swoboda
Seth Swoboda's Avatar
I restored one of these heaters. I used a gray hammer tone paint. It turned out really nice.
Old 11-28-2023, 12:28 PM   #16
Bob C
The fitment list show 1948-55 Ford pickups so it would be 6volt.
Old 11-28-2023, 02:02 PM   #17
kirkf
kirkf's Avatar
I use a simple polarity-reversing toggle switch with the 6551021 motor in my '40s Ford heater.
Yes also a good solution.
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
Old 11-28-2023, 04:32 PM   #18
41 Ford PU
I'm making progress. Ecklers has a wiring harness that I ordered.
There is a place in California that would rebuild the Redmond motor I have.
I'm not very fond of their price structure though.
$75.00 to test it and $425 additional if it needs to be rewound.
I'm having conversations with a guy in Florida who can also rebuilt it. I'm waiting for his reply about the cost.
But I'm at least making progress.
Old 11-28-2023, 05:49 PM   #19
cadillac512
cadillac512's Avatar
Would Fred at Southside Obsolete have a NOS one?
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 11-28-2023, 07:31 PM   #20
tubman
tubman's Avatar
Ya know, after watching what's been happening with him over the last ten years, I would bet on it.
I would certainly check.
