Old 11-08-2023, 11:27 AM   #1
fordfixer
Default 1940 v8 timing
Can the timing on the engine be tweaked, with the distributor on the car. It runs pretty good but seems to lack power. Can only get 30 mph in second gear and doesn’t like third gear at all.
fordfixer is offline   Reply With Quote
Old 11-08-2023, 11:53 AM   #2
marko39
Default Re: 1940 v8 timing
If you have the stock distributor the timing is set by moving the slide in the side. It would be best to send it to someone who has a distributor tester so it can be set correctly.
marko39 is offline   Reply With Quote
Old 11-08-2023, 12:30 PM   #3
fordfixer
That has already been done. He is a well know guys who has the machine to set them up.
Old 11-08-2023, 12:36 PM   #4
Seth Swoboda
Seth Swoboda's Avatar
If your distributor has been properly set up on a distributor tester machine, I'd say you have another issue.
Old 11-08-2023, 12:47 PM   #5
47topless
47topless's Avatar
A vacuum leak would give you those symptoms.
47topless is offline   Reply With Quote
Old 11-08-2023, 01:00 PM   #6
petehoovie
petehoovie's Avatar
You're only running on 4 cylinders. One barrel of your two barrel carburetor is clogged...
Old 11-08-2023, 01:08 PM   #7
Seth Swoboda
This actually happened to me once. I recently saw an ad for a V8 Ford and the ad said it had a single barrel carburetor.
Old 11-08-2023, 01:59 PM   #8
GB SISSON
GB SISSON's Avatar
Have you done a compression test? Has the carb been rebuilt? Spark at all 8 cyls?
Old 11-08-2023, 03:00 PM   #9
Seth Swoboda
A compression check would be in order. I just replaced an engine, 21 stud, that had 60 psi per cylinder. It ran well but lacked a lot of power through the RPM range/gears.
