Old 10-28-2023, 07:31 PM   #1
Netclassics
Default Distributor for -52 8ba ???
I have a 8ba from 1952 in my car. What exactly is the correct vaccum distributor called / named or numerärs?
Need to find i good one as mine does not work
I have my 6v system still in the car
My very best regards
Lars Hedstrom Sweden
Netclassics is offline   Reply With Quote
Old 10-28-2023, 08:41 PM   #2
Merc Cruzer
Merc Cruzer's Avatar
Default Re: Distributor for -52 8ba ???
It is call a: Load-o-matic. Pictures are worth a 1000 words. Hope this helps.
File Type: jpg Finished mine on left new one on right (5).jpg (55.8 KB, 13 views)
Merc Cruzer is offline   Reply With Quote
Old 10-28-2023, 10:23 PM   #3
petehoovie
petehoovie's Avatar
Old 10-29-2023, 06:42 AM   #4
V8 Bob
V8 Bob's Avatar
There are two styles of 8BA distributors, aluminum and cast iron, and they use different front covers, so you need to match what your engine has.
It maybe easier to fix what is not working with your present distributor. What does not work?
Old 10-29-2023, 07:15 AM   #5
corvette8n
corvette8n's Avatar
https://thirdgenauto.com/contact-us/
You can send it to Michael at Third Gen Automotive, he is a member on this forum, he can rebuild it for you. This way the distributor will be original to your car.
Old 10-29-2023, 08:07 AM   #6
jimvette59
jimvette59's Avatar
Exactly what doesn't work on your distributor ?
jimvette59 is offline   Reply With Quote
Old 10-29-2023, 10:02 AM   #7
38 coupe
38 coupe's Avatar
Most 8BA era distributors work well after typical tune up efforts: verified good or new vacuum advance, verified free to move plate, good or new points, good condenser, new rotor, new cap. Set initial timing and go. This is a "modern" single points type distributor that is easy to work on and conveniently located. These are easy in all the ways the earlier distributors are difficult.
