Old 10-26-2023, 10:42 AM   #21
flatjack9
flatjack9's Avatar
Default Re: WTB Full Flow Oil Conversion Kit
Originally Posted by Bored&Stroked View Post
Hey FlatJack . . . that rear main really doesn't look like crap went through it, more like the clearances were too tight and it got hot? My guess is that it didn't have enough oil and film-strength to prevent journal to bearing surface wear.
What type of bearing clearances were you running for the rear main? I always open the rear main up a bit more than the front two - as it tends to expand more due to the heat from the clutch.
Just curious if you happen to know?
Thanks!
B&S
A friend of mine built it and ran it in his dragster for a number of years. He's built several flatheads and being a machinist is very particular and capable. However, anything is possible,
Old 10-27-2023, 02:23 PM   #22
Ronnieroadster
Ronnieroadster's Avatar
When using a flathead for racing I learned the rear main bearing needs a lot of clearance to survive. From what I see in your picture that damage is from its racing life not the type of oil filter system you were running. If it was filter related every bearing would show damage not just the rear main.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 10-27-2023, 02:23 PM   #23
Tim Brown
Tim Brown's Avatar
You guys are using oil filters? I guess I've been lucky the last 50k+ miles running without one. hmm
Tim Brown is offline   Reply With Quote
Old 10-30-2023, 11:40 AM   #24
Bored&Stroked
Bored&Stroked's Avatar
Ronnieroadster
What Ronnie just said! LOL
Old 10-31-2023, 11:26 AM   #25
Ol' Ron
Ol' Ron's Avatar
I've built too many engines with the Factory 66/95 oilfilter system To criticize it!!! Yes there are better systems, but this system is better than the original, and simple to make.
Old 10-31-2023, 01:16 PM   #26
Newc
Newc's Avatar
A V8 club member had big problems with a full flow filter system- starved his bearings. Crazy Bill in Dallas, Or knows all about it. Newc
Old 10-31-2023, 01:22 PM   #27
Ronnieroadster
There's a simple answer to that problem. When the oil lines to the filter are connected backwards that's what starves the bearings . The system/conversion is not at fault its the individual who connects the oil lines incorrectly.
Ronnieroadster
