Old 08-26-2023, 07:06 PM   #21
shew01
shew01's Avatar
Default Re: USB Charging Port Question
Originally Posted by eagle View Post
https://www.ebay.com/itm/26583140094...3ABFBM9LWX78Vi
This one works, 3Amp output, dual ports, no case ground. It is for 12V but it works down to 6. Cheap too.
Thanks for the post. :-) I just bought one on your recommendation. Slow shipping though. It’s supposed to be here by September 25th.
Old 08-26-2023, 07:10 PM   #22
The Master Cylinder
The Master Cylinder's Avatar
Maybe because it is shipping from Shanghai, China??
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 08-26-2023, 07:40 PM   #23
philcobill
philcobill's Avatar
Originally Posted by Ramman View Post
I watched the video but couldn't see the link to the outlet he used.
https://www.amazon.com/dp/B082D8WKNW?...
philcobill is offline   Reply With Quote
Old 08-26-2023, 07:51 PM   #24
philcobill
philcobill's Avatar
Originally Posted by Dino's A View Post
Paul Shinn addressed this issue with a great video. It's on
Youtube.
https://youtu.be/O2q2ndf7jmY
I love the video, installing the Car Cigarette Lighter Socket is a great idea. I wonder however, if there are differences in the chargers themselves. The one he used could handle the Model A 6 V voltage. But I understand that not every charger (made for 12 Volts) can handle low voltages.
I would like to know what would be the best or better chargers to use.
Old 08-26-2023, 07:58 PM   #25
philcobill
philcobill's Avatar
Originally Posted by 5lugnuts View Post
The cigarette lighter plug (male) from the phone or GPS only lets five volts pass through. Phone and GPS are five volts devices as are others that are meant to plug into a cigarette lighter socket.
So, to be clear, are you saying that the 12 V input chargers will accept the 6 V from the Model A system and still charge?
Old 08-26-2023, 08:21 PM   #26
shew01
shew01's Avatar
Yup. Most likely.
Old 08-26-2023, 09:11 PM   #27
JayJay
Likely goes without saying, but this applies to the USB chargers only. Other plug-in accessories such as GPS, CB, radios, radar detectors, etc. actually do require the full 12 V from the cigarette lighter adapter.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 08-27-2023, 04:06 PM   #28
5lugnuts
GPS, CB radio, radar detector apps are available to download to your phone from the internet. Google to find them. If you use a battery maintainer in the garage, hard wire the + and - leads to your bat cables. Cut the cord between the maintainer and the + and - leads and install a disconnect plug for reattachment. The side of that plug that comes from the battery can be used with half of another detachable plug wired to power and charge your phone loaded with all the apps you prefer. The male cigarette wiring plug that comes with your phone only allows 5 volts through because that is all the phone needs. It works great! You must use that male cigarette plug that came with your phone and you must wire the female socket like in a modern. Double check your wiring polarity. The device mentioned from Walmart would be an excellent choice also.
Last edited by 5lugnuts; 08-27-2023 at 04:58 PM. Reason: needed to write more instructions
5lugnuts is offline   Reply With Quote
Old 08-28-2023, 11:08 AM   #29
JayJay
Do be aware that the GPS function in cell phones is reliant upon a cell signal to download the background map. When you are in the middle of nowhere without a cell signal you might be able to get GPS coordinates, but you won't be able to see where you are on the map. I run into this fairly regularly in the mountains and a lot of places in the Northern Midwest woods.
JayJay
Old 08-28-2023, 04:02 PM   #30
Rusty30roadster
I wired in a 12v version of something like this 6v version.
https://www.walmart.com/ip/Car-DC-6V...SellerId=18988
I cut the back off of my cigarette lighter housing and snuck the usb charge port in the sleeve. Pretty slick. Here’s the 12v product I used.
https://www.amazon.com/gp/aw/d/B0B8C...b_b_asin_title
I also agree with your son in that your not going to be charging very quickly, most of these chargers are 1.5a to 3a if you are lucky.
An alternative solution is using a battery pack like below. It is “something extra” to carry but very effective. They even sell these chargers with hand warmer functions built in.
https://www.amazon.com/gp/aw/d/B07XF...b_b_asin_title
Rusty30roadster is offline   Reply With Quote
