#21 |
make sure your rods clear the bottom of the cyls , you will know as you put the pistons in may have to relieve the cyl a bit, mine being bored to standard left a small ridge at the top, a tight compressor let the rings clear the ridge.
good luck kurt |
#22 |
Next question
The book says the measurement between rear crank bearing and crank should be .0015 max. I’m at .003. Am I screwed? How do I fix? 0230709F-B5C1-45D8-BDF3-73AA068DD1EE.jpg
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
#23 |
Are you measuring end play? If yes, you need more than 0.0015, that dimension is for bearing ID to crankshaft OD.
#24 | |
.003" end play on that thrust bearing is perfect. Sure the book doesn't say .015 max? Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
#25 |
I like the end-play to be about .004 to .008. If you're down around the low-end, you should be good.
You should check it with a dial indicator and magnetic mount. Then move the crank back/forth with a big screw-driver between a counterweight and the block (gently!) and see how much end-play the indicator shows you. |
#26 | |
#27 |
Sunday morning questions.
First up, gear that goes on the crank that spins with the cam, any tricks to getting it on? Do I need to heat it up or just coerce it with a hammer? I started tapping with a hammer but didn’t want to get too agressive before I consulted. The book just says “install the gear” essentially. Second, what is this piece in the photo? Need to know before I go much further so I don’t have to back track. B97A0FD5-B492-42DC-99B7-A2D0B10FDA05.jpg 95A9348E-BB07-461C-BC46-CCEF4E9EDA7C.jpg Third, what about this hole in the rear crank bearing cap? It’s threaded. Nothing in my box of parts looks like it should fit. Red marker pointing to hole in photo. B75EB8EE-6262-4D0D-87A3-522815C5422F.jpg
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ Last edited by busmania; 08-13-2023 at 09:46 AM. |
#28 | |
The second pict, there is an approx. 3" tube was a spoon/mouth on the end that inserts in there. I'll try to take a picture of what it looks like on a cap. May not be until tomorrow. |
#29 |
Looking back at my old sludgy tear down photos, there appears to have been nothing screwed into the hole on the main cap.
#30 | |
I have multiple rear caps without them. Stock and as is from the factory, they had them. I'll defer to others if it is needed. |
#31 |
Yep, if it’s supposed to be there I prefer it to be there! Anyone got the tube for sale?
#32 | |
#33 | |
I wonder what the function of that tube is? |
#34 |
There is also a slinger that goes between that sleeve and the crank gear.
#35 | |
#36 |
I've used this conversion, and it works quite well
Granps |
#37 |
My understanding:
The sleeve shown is sometimes part of the front pulley, sometimes a separate piece. Check your pulley is compatible. As stated, don't forget to put the slinger on first. Again, as stated, Ford discontinued the small tube on the rear main cap. Don't worry about it. Mart |
#38 |
On the spiral wound slinger. Some 49-53 crankshafts used a pulley where the seal surface was an integral part of the pulley - like the earlier engines had. Others, used this little sleeve that slides on the crankshaft after the main gear and slinger are in place. If you're running a modern "doughnut" seal (black round rubber thingy), then you usually put a speedy repair sleeve over the stock one so that the spiral grooves don't wear out the modern front seal.
#39 | |
BELOW is an explanation (in someone else's words) of why that tube was originally necessary, as well as WHY IT IS NO LONGER NEEDED. "The very early engines 32-34, had no crank case ventilation, and slinger rear main. Crank case windage presurizes the interior of the engine, which looks for a place to escape. Major escape route is through the labyrinth, so a return pipe was fitted, the open end of which is immersed in the oil in the pan. Therefore, that possible/probable/definite oil leak is eliminated [to a degree] Beginning 1935, and all subsequent production, the crankcase has positive ventilation, therefore there is no presurization of crankcase, which precludes the blowing out of oil through the labyrinth, therefore, although the rear main cap was tapped for the fitting of the return pipe, the pipe was not fitted during production. Certain 'dump truck' applications, whereby a heavy load could lift the front wheels off of the deck, could indeed, tilt the rear of the engine sufficiently to allow oil to leak out through the labyrinth, so in that application, the return pipe was fitted." To satisfy your curiosity, BELOW is a picture of the tube in question. Coop |
#40 |
I called and left a message for this gentleman. Have both parts nos Ford
