Old 06-04-2023, 08:01 PM   #1
draggin49
Default Sudden violent vibration …
I recently purchased a 36 ford roadster , original drivetrain . It had driven pretty smooth up to this point . I was on a drive last night and suddenly the car began to shake violently, I was having to really hold onto the steering wheel it was so bad . I limped the car over and called AAA and had it towed to my house . Any ideas on what might be the culprit or how I might better figure out ? Should I try and pinpoint when the vibration starts ? Or if it still vibrates if I put clutch in ?
Any tips or insight is appreciated
File Type: jpg 6A4EE026-7EAE-42BF-9A6D-B45B1BE201CC.jpg (56.5 KB, 419 views)
draggin49 is offline   Reply With Quote
Old 06-04-2023, 08:20 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: Sudden violent vibration …
From your description it sounds like wheel tramp. Some folks call it the death wobble.
Radial tires? They will exaggerate this condition especially with worn front chassis pieces.
Me? And again, from what you describe, I'd check the front chassis VERY carefully for worn parts. Tie rod ends, spindle pins, spring, shocks and finally, PROPER alignment.
It appears the car sits very low, much lower than stock. Many guys, without the necessary knowledge, simply lower the car without realizing the geometry changes along with the height.
Old 06-04-2023, 08:41 PM   #3
draggin49
I actually am running a set of old bias ply tires on it. Yeah, the car was already lowered before I got it so I will try and have someone check out the geometry . I will also try and go through the list you made and go from there .
Old 06-04-2023, 08:49 PM   #4
petehoovie
petehoovie's Avatar
Old 06-04-2023, 08:55 PM   #5
Zeke3
Zeke3's Avatar
The only way, that I am aware of, to get out of the vibration is to bring the car to a stop. Then when you start again the vibration will be gone until you hit the next pothole or railroad track that will start it all over again. It can be a pretty random occurrence, but not one you ever want to repeat. Good luck with your investigation let us know what you find.
Zeke3 is online now   Reply With Quote
Old 06-04-2023, 09:08 PM   #6
50fordcoupeman
50fordcoupeman's Avatar
I had this happen to my modern pickup last summer. It went to driving perfectly to like driving on railroad tracks. After chasing a lot of "what ifs" and spending considerable money, it turned out to a tire that was disintegrating from the inside. The tire was only 5 years old. Needless to say I replaced all of them.
50fordcoupeman is offline   Reply With Quote
Old 06-04-2023, 10:11 PM   #7
Flathead Fever
Flathead Fever's Avatar
That is usually caused by play in the front steering or suspension. With a little movement allow it allows a vibration that grows and quickly becomes violent. It usually takes a combination of things for that to happen. Possibly loose parts, bad shocks and tires out of balance. It's hard to believe a vehicle can go from being perfectly smooth to that violent from one bump in the road.
With the tries on the ground, have somebody turn the steering wheel from side to side and look for play in the tie-rod, draglink, steering box, spring perches. front spring U-bolt clamps, kingpins. loose wheel bearings, broken spring leaves broekn fron cross member.... Then jack up the frontend and spin the tires to see if there are any bulges in the sidewalls or tread (separation) or if they are badly out of round. Bias ply tires get flat spots from sitting too long and you have to drive them miles to get them round and running smooth again. Most tires will have be slightly out of round but it should not be easily noticeable. They might also be out of balance. If you do not see any weights on them, check the front and back of the rim. I would definitely have them balanced. Weak shocks can also contribute to "speed wobble". They allow the movement to get larger and larger.
At the phone company we had F-350 aerial boom trucks that were loaded to the maximum gvw, a lot of weight on the rear axle. If everything was not perfect in the frontend, they would go into violent speed wobbles. When the drivers complained, I would test drive them at about 50 mph across some nearby railroad tracks, if I went across them at just the right angle, I'd better be holding on, it was liking a bucking bull. No stopping the shaking without coming to a complete stop. It's literally yanking the steering wheel out of your hands because of those heavy front tires, it continues as you slow down until you finally come to a complete stop. Then it is fine again, maybe fine for months. Usually that was from loose bushings in the front panard bar, from the frame to the straight axle. This would allow the axle with the parallel front springs to move from side-to-side, it did not take much play in those busking. Every service we checked them. We stocked a panard bar so we could quickly replace it during the service and then later we could press in and out the bushings and have it ready for the next truck. Some of those trucks, the only way to stop the speed wobble were with new panard bushings, the addition of a steering stabilizer, take any play out of the steering box, set the toe-in, new front shocks and new front tires. Because the rear weight could very on those trucks daily the caster was constantly changing which also might have contributed to it. Everything had to be absolutely perfect. As soon as the front tires got the least little uneven wear pattern the speed wobble would start again. We would mount new tires and balance them and save the slightly worn ones to run on the rear on something else. A couple years later the F-350's started coming with factory steering stabilizers so we knew Ford was having problems with them. That didn't stop the problem either. Then a couple years ago I went out and bought one of these 1994 F-350 aerial trucks with brake problems, (no brakes at all) for $2300.00 so I can trim my trees, roof the house and paint the second story and not fall off a ladder. I don't plan to be going over 50 mph in the yard so I'm not worried about speed wobbles. I looked under it the panard bar bushings are shot.
Old 06-04-2023, 10:17 PM   #8
draggin49
These tires look like they’re old , lots of spiderweb cracking in whitewall . I think I’m gonna order a new set of tires just to know what im starting with . Those and an alignment , if it’s still doing it I can at least rule out those items .
Old 06-04-2023, 10:29 PM   #9
tubman
tubman's Avatar
I think you might want consider raising the ride height a bit as well. Depending on how it is lowered (6" drop shackles?), there mght be some intrinsic problems.
Old 06-04-2023, 11:51 PM   #10
deuce_roadster
deuce_roadster's Avatar
Did this happen when you were turning a corner? The front tires look like they could catch the edge of the fender.
Old 06-05-2023, 12:04 AM   #11
draggin49
The vibration started in a slight curve not sharp enough for tire to rub, but then it was a long straight away and vibration kept goin .
Old 06-05-2023, 12:59 AM   #12
draggin49
https://carrillocustoms.com/products...r-opening-edge
I believe this ^^ kit is what the previous owner used to lower the front
Old 06-05-2023, 01:32 AM   #13
deuce lover
deuce lover's Avatar
Check also the steering box as mentioned for play when wheels are facing front.If it has the orig steering box you might consider replacing it with a '37-40 unit. I have had a '35 and 36 a few yrs back and lowered both of them ,replaced the steering boxes and had NO "death wobble" of course all tie rods ends were tight and kingpins were new.I ran both bias ply and radial tires also.I also used most of the parts you have pictured and did not split the wishbone.
deuce lover is online now   Reply With Quote
Old 06-05-2023, 08:07 AM   #14
Kube
Super Moderator
Kube's Avatar
Good point. Kinda what I'd advised in my previous post about someone not knowing the correct way to lower a car. Longer shackles, as you so rightly point out, are NOT the right way.
Old 06-05-2023, 08:23 AM   #15
tubman
tubman's Avatar
Duplicate post.
Old 06-05-2023, 08:27 AM   #16
tubman
tubman's Avatar
It might be the differing angles of the two pictures, but your car looks a lot lower than the one in the ad.
Old 06-05-2023, 08:32 AM   #17
deuce lover
IMO,the tires are to big.Here is a pic of the 35 sedan I had.Dropped axle and 16" 4.5 wide Kelseys in front with WW radials.Its now in Sweden.
Old 06-05-2023, 09:06 AM   #18
32phil
This problem has been discussed many, many times on this forum.
On a stock unmodified Early V8
Check everything !
Start with tire pressure. Have all the wheels spin balanced. Look for bent rims, warped, damaged, deteriorating tires. Don't forget the lug nut holes.
Then do a super critical inspection of the rest of the front suspension. Pay close attention to toe in/toe out and Caster. Look for bent, worn, incorrect/missing parts.
On modified cars / Hot Rods All of the above applies.
The critical issue with cars with big rear tires and small front tires is the caster.
On my 32 Brookville roadster the issue was the caster.
I have previously posted about the death wobble happening on this car.
Basically, it was a fresh build (20 yrs ago) everything was new or 100% rebuilt including the 32 steering box. The best parts available. No Expense Spared.
With the big and little tires the caster had changed causing the wobble to occur.
There is a spacer that is available that mounts above/between the stock wishbone and the center crossmember. This drops the ball down and corrects the caster and stops the wobble. Please use the SEARCH Function on this site to read the monumental amount of discussion concerning the death wobble.
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 06-05-2023, 10:12 AM   #19
draggin49
Originally Posted by 32phil View Post
This problem has been discussed may many times on this forum.
Check everything !
I will do a search to find further info . I will also go through your checklist. I think I’m gonna try a set of those new diamond back radials that look like a bias ply .
Also gonna try and figure out easiest way I can raise the front /back a little bit . I will double check , I think right now it has 6.00x 16 on front and rear for tire size
Old 06-05-2023, 10:21 AM   #20
draggin49
I will double check the rear tire size , I think the car has 6.00x16 front and rear
I tried to take a side pic of my front tire . Maybe I can bring it up a little bit in front and rear . Is there an easy way to do that or am I gonna have to buy a lot of new parts to make it happen? I’m not familiar with with raising ride height
File Type: jpg 71A3AD9C-393C-439A-AECF-734B716706BA.jpg (99.0 KB, 251 views)
