Old 04-13-2023, 12:52 PM   #1
ted55ford
ted55ford's Avatar
Default Petronix upgrade
Hey All,
What are the best plugs to use that would work well with a Petronix upgrade?
I have the 292 v8..
Thanks all?
1955 FORD FAIRLANE
1967 FORD MUSTANG CONV.
ted55ford is offline   Reply With Quote
Old 04-13-2023, 03:28 PM   #2
paul2748
paul2748's Avatar
Default Re: Petronix upgrade
I use the usual Autolite 46's.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-13-2023, 06:50 PM   #3
Dobie Gillis
Dobie Gillis's Avatar
I second the motion ^^^^
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 04-14-2023, 12:31 AM   #4
Alaska Jim
Alaska Jim's Avatar
what do you recommend for plug gap when using the 46's with the Pertronics? just curious
Alaska Jim is offline   Reply With Quote
Old 04-14-2023, 01:23 PM   #5
Ole Don
Ole Don's Avatar
On my 55 with Pertronix, I ran NGK at .032 in a hot rodded 312.
Ole Don is offline   Reply With Quote
Old 04-14-2023, 08:35 PM   #6
Alaska Jim
Alaska Jim's Avatar
Thanks Don, which NGK are you using?---- Jim
Old 04-15-2023, 08:13 AM   #7
ventport
Make sure you use the Pertronics coil. All of the failures I have ever read about were using someone else's coil.
ventport is offline   Reply With Quote
Old 04-15-2023, 11:59 AM   #8
ted55ford
ted55ford's Avatar
Thanks everyone....
1955 FORD FAIRLANE
Old 04-15-2023, 04:45 PM   #9
dmsfrr
dmsfrr's Avatar
Depending on which version of Pertronix you get, some of them will burn up & quit if the power to them is left on without the engine running.
Old 04-16-2023, 04:46 PM   #10
Ford Freak
I second that, and make sure you get the Igniter II version, NOT the Igniter I.
Then use whatever coil they reccomend.
Going on 10 yrs. now in my car w/no problems. Only way to go! IMHO
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 05-18-2023, 12:04 PM   #11
Fairlanephantom
Personally, I have the Igniter I with Autolite 46s and just an off the shelf coil from Pep Boys and I haven't had a problem. Its been going for close to ten years and never had a spark issue.
Fairlanephantom is offline   Reply With Quote
Old 05-18-2023, 10:15 PM   #12
fordor41
fordor41's Avatar
I used the Ignitor I in our '41 with a 302 for many years with only one module burn out and that was caused by a bad coil. other than that I had great luck. when our first module quit I tried another that I had for about 5 yrs as a spare. still no luck. Called PertroniX and they said send them both back which I did and they sent me 2 new units at no cost and said check the coil. that's when I discovered the coil was bad.
fordor41 is offline   Reply With Quote
Old 05-20-2023, 02:42 AM   #13
54VICTORIA
54VICTORIA's Avatar
I just put an igniter II with the Pertronix coil in my ‘54 which has a ‘60 292 engine. Installed per instructions and it fired the very first crank, also appears to have more power while driving it.
54VICTORIA is offline   Reply With Quote
