Old 01-23-2023, 12:57 PM   #21
Lawson Cox
Lawson Cox's Avatar
Default Re: Distributor outer cap gaskets on dome distributors
OKAY, I have sat down with all parts in hand, scratched my head, and other areas, and see how everything is supposed to fit together and work.
I have talked with Michael and he says he usually just puts everything together without the gasket. With all the problems I have had on this, I can understand why.
Anyhow, my problem has apparently been, primarily, that the inner circumference of the gasket, or at least the ones I have gotten, is a little too small to fit on the inner cap, without stretching the gasket to the tearing point. The gasket also does not match up with the outer surface of the caps.
There is also an alignment tab on the gasket side of the inner cap, which prevents the gasket from laying flat on the surface of the inner cap as it should. If I cut the gasket, and separate the ends to where they just barely clear that little alignment tab, the gasket will lay flat and will also extend out to where it aligns with the outer edge of the cap, perfectly.
Maybe I have a bastard aftermarket inner cap, or a cap for the earlier distributor or something, I dunno. I have ordered a new gasket set and, if it don't fit, I'll do whatever modifications that are necessary to make it look right, at least.
With this being only a display engine, it only needs to appear correct. Between the problem with this gasket and a correct fan, (which is a whole different story) this project has really been a headache. Other than this, I have really enjoyed this project and I am glad to be very close to its conclusion.
Thanks for all the help, Guys and Gals
Old 01-23-2023, 01:02 PM   #22
Lawson Cox
Lawson Cox's Avatar
Originally Posted by DavidG View Post
Depending on the color of the gaskets, the outer edges are visible from the outside. Do you honestly think anyone in Auburn gives a damn?
To be perfectly honest, which I try to be, always, I seriously doubt they do. But like you, I'm sure, I want it to be 100% in every possible way.
Old 01-23-2023, 01:12 PM   #23
DavidG
DavidG's Avatar
Okay, but something is wrong in what you describe regarding your inner caps. The alignment slot in the inner cap for the tab in the outer cap does not interfere with the gasket as the gasket fits around the raised area of the inner cap. The alignment slot in the inner cap is inboard from where the gasket seats on the inner cap.
The gaskets are prone to shrinkage with age and older ones are a bit of a struggle to attach around the perimeter of the raised circle on the outside of the inner caps. You may indeed have to trim away some of that shrunk gasket material in order to install the gaskets on the inner caps.
Old 01-23-2023, 01:33 PM   #24
Brian
Brian's Avatar
If, indeed the gasket[s] have shrunk with age, simply soak 'em in warm water; they'll grow back to original size. I thought you stated that you've tried fitting various different brands of these gaskets, always with the same result?
Old 01-23-2023, 02:14 PM   #25
Cecil/WV
Cecil/WV's Avatar
People in Auburn care about as much as concourse judges care about correctness on '32 Fords!
Cecil/WV is offline   Reply With Quote
Old 01-23-2023, 02:53 PM   #26
Lawson Cox
Lawson Cox's Avatar
Yes, and I have tried soaking them, without any improvement, I think they are just manufactured to the wrong specs. I would hazard a guess that really only one outfit makes them all. I'll see when the "new" ones arrive. If they don't fit I'll return them and have some cut. That will be almost as cheap as what they charge for gaskets. I'll just have to drive about 50 miles round trip.
Old 01-23-2023, 02:59 PM   #27
dad35
Red face Re: Distributor outer cap gaskets on dome distributors
I do David. We are actually trying to correct displays which are not correct. May take a while but they are working on it.
dad35 is offline   Reply With Quote
Old 01-23-2023, 03:23 PM   #28
35fordtn
35fordtn's Avatar
Old 01-23-2023, 03:30 PM   #29
petehoovie
petehoovie's Avatar
Originally Posted by 35fordtn View Post
Attachment 508190
Old 01-23-2023, 05:00 PM   #30
jimTN
Not correct but mason jar rubber gaskets work fine.
Old 01-23-2023, 05:14 PM   #31
Kens 36
Kens 36's Avatar
Given the recent pictures at the museum, those gaskets are essential
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 01-23-2023, 05:18 PM   #32
Zeke3
Zeke3's Avatar
Thank you for the pictures Michael. Note that there are no notches on the gasket surface on the outside of the terminal plate.
Zeke3 is offline   Reply With Quote
Old 01-23-2023, 06:36 PM   #33
35fordtn
35fordtn's Avatar
Becuase of where they sit no notches are needed
Old 01-23-2023, 06:42 PM   #34
Robert/Texas
Robert/Texas's Avatar
Post #21 mentions putting everything together without the gaskets. I'm not sure that I would agree with this. When the distributor quit on my '37 Ford I found that thin paper gaskets were used between the caps. I noticed that the wire bales were not real tight. Both inner and outer caps showed slippage and the nibs were damaged. With new caps and cork gaskets the bales go on tight. I believe that the previous owner assembled the distributor this way. I put about 3200 miles on the car until this happened. Perhaps the gaskets could be eliminated if the bales were bent some way.
Robert/Texas is offline   Reply With Quote
Old 01-23-2023, 09:38 PM   #35
35fordtn
35fordtn's Avatar
I bend my bails so they fit tight. I do not drive my cars in the rain ans simply dont run the gaskets. Just a personal preference. Nothing wrong with running them
Old 01-23-2023, 10:14 PM   #36
Karl
Karl's Avatar
But placed in an unfortunate location for servicing.
Say that again -I'd like a dollar for every radiator scrape my knuckles have taken ! Took me a while to figure out that the whole job is a lot easier if the generator and fan is removed first ( a job that only takes a minute or two )
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 01-24-2023, 04:38 PM   #37
Lawson Cox
Lawson Cox's Avatar
I have smoked over my parts carefully, and the pictures which have been posted. Thanks a bunch for the pictures by the way. As soon as my new gaskets arrive from Michael I will remove the passenger side wire looms and check out everything carefully to find out just what my problem is and, following the photos hopefully I can make things all better. I will update you as I go along. Hopefully with success. Lawson
Old 01-24-2023, 04:50 PM   #38
Seth Swoboda
Seth Swoboda's Avatar
I have replaced these distributors with a car up in the air on a 2 post lift and the lower radiator splash shield removed. Either way a simple job takes a little longer. Although the look of the helmet distributor is worth it.
Old 01-24-2023, 06:17 PM   #39
ford38v8
ford38v8's Avatar
This is the way to do it. No messing with fan belt tightness, no backaches, no knuckle scrapes. Run the front wheels up on a curb if you don't have ramps.
Use a long headless bolt to assist in alignment till you have the other two bolts in place.
Alan
Old 01-24-2023, 09:43 PM   #40
Lawson Cox
Lawson Cox's Avatar
Hey Seth and Alan. At my age I'm just grateful that this engine is mounted on a stand and I have unfettered access to the distributor. LOL
