Old 05-28-2010, 09:26 AM   #21
DD931
DD931's Avatar
Default Re: Frustrating Oil Leak
Thanks for the feedback!!
Norm
DD931 is offline   Reply With Quote
Old 05-28-2010, 11:08 AM   #22
Rocketsled
Rocketsled's Avatar
Try installing a PCV Valve. Relieving the pressure inside the engine might effect the oil leak. My 59 A/B leaks not! I installed a full-circle lip-seal on the front of the crank and a PVC tappled into the underside of the intake manifold. The PCV was from an early Mustang 6 cylinder and has pipe treads on one end, so it screws right into place. No hoses!
I use fluid grease, NLGI #000 with MoS2 (Moly) in the gearbox and steering gearbox, and they don't leak either.
Rocketsled
Rocketsled is offline   Reply With Quote
Old 10-14-2013, 08:59 PM   #23
ken-r-mer
An oil leak coming out of the slot at the bottom of the bell housing could also mean your trans front seal is worn as I found out when I swapped a 3 speed for an overdrive unit.
ken-r-mer is offline   Reply With Quote
Old 10-14-2013, 10:05 PM   #24
BILLF/TRF
BILLF/TRF's Avatar
It has been so long since I made this post that I forgot what I did to solve the problem. I looked through my records and found a receipt for an oil pump drive cover from Baxter Ford Parts. Then I looked back at my engine photos and saw the culprit--a brass screw extending beyond the engine surface so that the old cover could not seal the area and was warped in the process of tightening. I filed off the extruding screw head, inserted the gasket and new cover and "presto" no more leaks (well maybe a couple of drops once in awhile). I hope my pictures come through!
BILLF/TRF is offline   Reply With Quote
Old 08-23-2014, 04:34 AM   #25
bonner
good to hear, I hope after this fact the oil flow is remedied/finger cross to you
bonner is offline   Reply With Quote
Old 12-21-2022, 08:34 AM   #26
richard crow
if you use a new modern oil seal expect a oil leak. the new seals are junk find an original seal. those new seals are wimpy & soft.the old style contain asbestos the new don't contain asbestos don't worry you won't die if you touch it
richard crow is offline   Reply With Quote
Old 12-21-2022, 11:18 AM   #27
whizzernick
whizzernick's Avatar
does a 59-ab use a slinger rear main ? If so is that the problem ?
whizzernick is offline   Reply With Quote
Old 12-22-2022, 02:27 AM   #28
Newc
Newc's Avatar
The PVC advice is spot on. I welded up the 59A style pan breather with a pipe plug, and routed that opening to a PVC- No more leaks- Negative crankcase pressure!. Newc
Old 11-28-2024, 09:25 AM   #29
Bullerman
Is all this oil leaking causing clutch problems. Oil getting on the clutch disk. I am having clutch problems. As soon as I ease off the clutch pedal car starts shaking.
I haven't had the car long. I am going to clean it up good and see if I can tell anything about where the oil on the motor is coming from. I have a new pilot bearing, clutch pressure plate and throw out bearing. I sure hope the main seal isn't bad. I haven't noticed any oil on the driveway to speak of.
I hear you have to pull the motor to change a rear main. I am not equipped for that.
Bullerman is offline   Reply With Quote
Old 11-28-2024, 11:22 AM   #30
richard crow
when you replace the seal get an orignal one. those new seals are wipney junk . the new ones contain no abstoses. get an orignal you wount leak a drop .do you think ford could sell cars whith engs that wee pissing all over the floor the new seals are junk. i replace rear seals for t birds that just had the new crap leaking the orignal seale rope works that b.s of marking there spot is realeted to when cars had no real seal
