Old 12-02-2022, 01:23 AM   #1
Seth Swoboda
Seth Swoboda's Avatar
Default Carb renew paint
It looks like Eastwood has discontinued the carb renew silver paint. What are you folks using if anything after blasting to coat your carburetors? One source told me he uses Eastwood Diamond Clear satin.
Old 12-02-2022, 02:58 AM   #2
cas3
Default Re: Carb renew paint
Carbs from uncle max look perfect. maybe ask him what he uses
cas3 is online now   Reply With Quote
Old 12-02-2022, 03:43 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
That RATTLE-CAN carb rebuilder from Ct. ought to know!
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 12-02-2022, 05:08 PM   #4
ford38v8
ford38v8's Avatar
Coop
Somehow I just knew Ken's favorite thing would come into play here...
Goodnight Ken, wherever you are!
Alan
Old 12-02-2022, 05:50 PM   #5
47topless
47topless's Avatar
Why paint when you can Plate?
47topless is offline   Reply With Quote
Old 12-02-2022, 06:11 PM   #6
Kube
Super Moderator
Kube's Avatar
Who is ken?
Old 12-02-2022, 06:18 PM   #7
scicala
scicala's Avatar
Because the dichromate plating costs about $150 extra to get done, unless you have the chemicals and equipment to do it yourself.
Not everyone wants to pay the extra, and most don't have a show car that will be judged. The spray coatings arent the best, but are fuel resistent.
Sal
scicala is offline   Reply With Quote
Old 12-02-2022, 06:22 PM   #8
scicala
scicala's Avatar
Eastwood has also discontinued the carb renew bronze coating.
For aluminum castings I just use a small fine stainless brush and/or
0000 steel wool.
Sal
Old 12-02-2022, 06:26 PM   #9
DavidG
DavidG's Avatar
Besides, who wants a bronze finish on a carburetor whose production version (all pre WW II) did not have such a finish in the first place?
Old 12-02-2022, 07:46 PM   #10
51504bat
51504bat's Avatar
Originally Posted by Kube View Post
Who is ken?
A former member who rebuilt carbs but is now persona non grata and is banned.
Old 12-02-2022, 07:52 PM   #11
ford38v8
ford38v8's Avatar
I think Kube was just being sarcastic. He’s seen Ken’s rattlecan workmanship.
Alan
Old 12-02-2022, 08:40 PM   #12
Kube
Super Moderator
Kube's Avatar
Winner, winner, chicken dinner!
Old 12-03-2022, 12:23 AM   #13
GB SISSON
GB SISSON's Avatar
I'm confused... Has there been two banned carb rebuilders? Our NY guy certainly isn't a 'krylon overhaul' guy.
Old 12-03-2022, 01:20 AM   #14
Dodge
Has anyone tried Cerakote (the air dry one) on carbs? I have used it on several other items from exhaust headers to engine blocks and gun parts. Its a very thin film and
very very durable. They have many different colors to choose from, there should be something suitable for a carburetor.
I think I'll try some on a carb just for the heck of it. I have a satin black and a titanium
color.
Dodge is offline   Reply With Quote
Old 12-03-2022, 01:23 AM   #15
ford38v8
ford38v8's Avatar
Yup, you’re right. Two flameouts, one of which we miss.
Alan
Old 12-03-2022, 04:23 AM   #16
V8COOPMAN
V8COOPMAN's Avatar
Alan.... One of your heros, Ken/Ct. This pic found out there on the WWW.
T5 W/TORQUE TUBE
Old 12-03-2022, 11:03 AM   #17
Bored&Stroked
Bored&Stroked's Avatar
color.
Yes, with very good results. I've used a sort of satin nickel on the main Stromberg bodies and a semi-flat black on the bases and linkages. The whole reason in my case was not only looks, but the fact that fuel does not harm a properly coated carb. I know the satin nickel is not 'stock looking' - but I like it . . . so, nobody bitch at me! LOL
Blasting - you need to use a fine garnet blast (and not touch them with human hands), you need to bake the parts in the over to ensure they are 100% clean, apply the coatings and bake again. I've only used the bake-on versions - as I feel they are a better coating.
The masking process is the most time consuming as you don't want any of the coatings in the wrong places.
While it is a labor of love, the results are great and when fuel stains the bodies a bit (as it always does), then I just take lacquer thinner and a tooth brush, cleans them right back up.
Old 12-03-2022, 11:21 AM   #18
Kube
Super Moderator
Kube's Avatar
Originally Posted by bored&stroked View Post
yes, with very good results. I've used a sort of satin nickel on the main stromberg bodies and a semi-flat black on the bases and linkages. The whole reason in my case was not only looks, but the fact that fuel does not harm a properly coated carb. I know the satin nickel is not 'stock looking' - but i like it . . . So, nobody bitch at me! Lol
blasting - you need to use a fine garnet blast (and not touch them with human hands), you need to bake the parts in the over to ensure they are 100% clean, apply the coatings and bake again. I've only used the bake-on versions - as i feel they are a better coating.
While it is a labor of love, the results are great and when fuel stains the bodies a bit (as it always does), then i just take lacquer thinner and a tooth brush, cleans them right back up.
Attachment 504587
very impessive!
Old 12-03-2022, 11:38 AM   #19
Fred A
Fred A's Avatar
For decades I have favored good original chromate plating on old Ford carbs and other zinc components. Some out here (or one) may be chromate deniers which conflicts with my observations. Either way, I have some of the most handsome carbs that never were for my cars and collection. Perhaps I should move to Missouri. Good Luck: Fred A
Fred A is offline   Reply With Quote
Old 12-03-2022, 11:39 AM   #20
deuce_roadster
deuce_roadster's Avatar
i enjoy looking at superior workmanship like Kube's and B&S's carbs.
