#21 | |
Sal |
#22 | |
I put a fuel pressure regulator on my car because when I bought it the mechanical fuel pump put out zero PSI and I had to use the electric fuel pump to go down the road. The 6V fuel pump put out too much pressure for the Holley 94 carb, gasoline everywhere. At the time it seemed less expensive to add a fuel pressure regulator than rebuild or replace the mechanical pump. In hindsight, maybe not true, but that's what I did at the time. |
#23 |
Brother Blucar;
You wrote "Looking at your picture leads me to believe that you are over thinking the whole situation." Actually, I purchased the car this-a-way and obviously didn't think about it enough. This is my first classic car purchase and I confess to rooky fever. Come to think of it I don't think I've ever over thought anything mechanical. Now guitar playing and bowhunting, yes. Yes indeed! ha |
#24 |
To respond to comment re. posting pictures of the vehicle, here's some;
#25 | |
#26 | |
OK, I stand corrected... Whom ever installed the electric fuel pump in the car did not follow tried and true procedures for a full/part time system. I am a long time believer in the KISS Principle... It is quite amazing how often threads about installing an electric fuel pump come up on the Barn..
Bill.... 36 5 win cpe |
#27 |
MK charlie lets just keep it simple to start with just reverse the flow thru the pressure reg ensure its at 3-4 psi and it should be happy As time goes by read some of the previous posts and threads about this subject on here [theres lots of em] and then work out what you need to do to suit you and that is one sweet looking ride!!!! enjoy it
#28 |
Goldangit there Mr. MKCharlie.... You certainly made a grand entrance with that gorgeous vehicle. Get that plumbing turned around, put some George Strait on the philco (motorola?) and take your best girl there for a spin around town. I don't know or care what is original for a '40 interior, but that is stunning.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#29 |
It’s got neckin’ knob too, sweet.
#30 |
Well. here it is Wed. Wife and I fighting bad colds, but snuck out to the garage - a little Sunday night, a little last night and by golly by high noon today, It's all re-plumbed. And it seems to be all good. Car drives great. Idles smoothly and seems to have better power too. The pressure gauge reads between 4 and 5 lbs but I don't know if it is really an accurate instrument so am going to have it checked with a professional grade instrument that my friend has to be certain. No leaks, no gasoline smell, life is good. Posting pic of the re-routed set-up. Thanks to y'all for your advice and help.
Now to work on the windshield wipers. I feel another thread coming on..... |
#31 |
Vacuum wipers suck.....
#32 |
Much like the door to door vacuum cleaner salesman in a sales slump. Goes out for a drink with another door to door vacuum cleaner salesman. Asks his buddy, "how are sales going?" Buddy replies, "well sales lately have sucked but business is picking up." (insert groan here)
#33 | |
#34 |
That sure is a plumber's nightmare, but it ought to work for you if you crank down that regulator to less than 3 lbs max. Even still, you've got high pressure going to your mechanical pump, not a good setup there, as a diaphram failure will quickly fill your crank case with fuel.
Alan |
#35 |
ford38v8, Thanks for your comment. One question; You said "crank down that regulator" etc. I didn't know the regulator could be adjusted. Can you give me some more info as to how I can do that? I'm still getting 4-5 lbs. Thanks so much!
#36 |
The stud on top, bottom in your case. Screw it "out" to decrease pressure.
"5. The regulator comes from Holley with the regulator pressure preset (see table). However, for individual requirements, it may be readjusted. Loosening the regulator locknut and turning the adjustment screw clockwise increases the pressure. Decrease pressure by turning the adjustment screw counter-clockwise. WARNING! TURNING THE ADJUSTMENT SCREW ALL THE WAY IN WILL RESULT IN EXCESSIVE FUEL PRESSURE AND CAUSE THE CARBURETOR TO FLOOD. A FLOODED CARBURETOR CAN CAUSE A FIRE AND/OR EXPLOSION RESULTING IN PROPERTY DAMAGE, SERIOUS INJURY, AND/OR DEATH. ALWAYS USE A FUEL PRESSURE GAUGE BETWEEN THE REGULATOR AND THE CARBURETOR(S) WHEN ADJUSTING THE FUEL PRESSURE REGULATOR." Glenn |
