Old 10-08-2022, 06:56 PM   #1
retubjb
Default Is this babbitt?
I have no idea what this is, my friend was using it as ballast in a sailboat. Is this what babbitt material looks like? I have 40-50 pounds of it. If there is interest I can post it in the swap meet.
retubjb is offline   Reply With Quote
Old 10-08-2022, 08:46 PM   #2
Brkile
Default Re: Is this babbitt?
Yes. It says right on it, correct??
Brkile is offline   Reply With Quote
Old 10-08-2022, 09:23 PM   #3
retubjb
yes, it says nickel babbitt. I am wondering if it is what is used in car engines and if someone is interested in it.
Old 10-08-2022, 09:26 PM   #4
stevests
stevests's Avatar
I knew the manager at Non-Ferrous Metals a number of years ago - I used to work on his Dad's Model T - that appears to be a rather old ingot ! I had Ford formula Babbitt made for me at their plant.
stevests is offline   Reply With Quote
Old 10-08-2022, 09:44 PM   #5
retubjb
Yes, it's old. I have had this pile for almost thirty years. I am thinking of scrapping it but wanted to know if someone is interested in it before i do.
Old 10-08-2022, 10:59 PM   #6
J Franklin
J Franklin's Avatar
Delete. Bad info,
Old 10-09-2022, 08:40 AM   #7
History
History's Avatar
I know someone who might be interested, I’ll check and see and let you know.
History is offline   Reply With Quote
Old 10-09-2022, 09:05 AM   #8
rotorwrench
rotorwrench's Avatar
There certainly are different formulations for what is referred to as babbitt. The variations in alloys cover a wide range of uses from the small Ford engine bearings clear up to large engine bearings built to power the older ocean going ship in the era before steam turbines took over.
Old 10-09-2022, 09:13 AM   #9
nkaminar
nkaminar's Avatar
https://en.wikipedia.org/wiki/Babbitt_(alloy)
Old 10-09-2022, 09:56 AM   #10
Gene F
Gene F's Avatar
Diesel babbit is way softer. Be careful what you use.
Old 10-09-2022, 10:28 AM   #11
katy
katy's Avatar
Suggest you take one of the pieces to a scrap metal yard where they have a hand held metal x ray analyser machine, aka xrf metal analyzer. That will tell you what alls in the metal. Precious metal buyers also use these analysers.
https://irss.ca/product-category/scr...iAAEgKdzvD_BwE
Old 10-09-2022, 05:18 PM   #12
Joe K
Joe K's Avatar
"Power Nickle Babbitt" is among the best at least outside of Model A Land.
"Magnolia Metal" has nice period victorian bars - but is a true lead babbitt. I MIGHT do a saw arbor in Magnolia.
The Ford Babbitt formula was given by Steve Ross years ago in an online publication "Rebuilding the Model A Engine." I'm not seeing the publication online now which is too bad as Steve had studied out the Ford techniques and practice - and in another document tested and compared techniques. He put a lot of work into research.
He has Ford Babbitt at: 86%tin 7%copper 7%antimony.
He says the only suitable commercially available babbitt to be used on the Model A is 12SAE Babbitt: 89%Tin 7.5%Antimony 3.5%Copper (http://hirschmetals.com/wp-content/u...bbitAlloys.pdf)
Also he says DON'T use babbitt with more than 1/4 of 1 percent as nickle. Avoid altogether if possible. (This is a surprise for me with power plant/turbine experience - but turbine bearings are "pressure lubricated - the main oil pump "lifts" the turbine spindle before rotation. Technically there is no direct contact between journal and bearing.)
Too bad about the document being removed...
EDIT: FOUND the document within a reference here at Fordbarn.
https://www.fordbarn.com/forum/showpost.php?p=1823977&postcount=6
There is a PDF attachment at the link above. 13 pages.
Joe K
Shudda kept the horse.
Old 10-09-2022, 05:51 PM   #13
1crosscut
1crosscut's Avatar
I would be interested in one of them just as a curiosity piece to add to my walls of odd and interesting things.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-11-2022, 03:25 PM   #14
retubjb
Thanks for the information from those with knowledge. It helped me out greatly.
Old 10-11-2022, 03:28 PM   #15
retubjb
get ahold of me next week and we can work something out
Old 10-12-2022, 06:42 AM   #16
Kevin in NJ
Yes it is a grade of babbitt that could be used for the Model A engine. It is not the Ford blend, but will work.
http://nfmetals.com/babbitt-metal/
https://www.fordgarage.com/pages/babbittgrades.htm
That being said, pouring babbitt properly is a complicated process based on known science. It is not something to be done sucessfully by an inexperienced person. In fact, there are video showing current engine shops doing babbitt improperly. Babbitt poured improperly will fail in time long before it wears out.
The babbitt you have is likely worth more then the cost of the lead needed to replace weight in the sailboat. There are people that would be happy to pay for it. Oh, shipping is best by USPS one rate boxes.
