Old 08-28-2022, 01:46 PM   #1
jrvariel48
jrvariel48's Avatar
Default 1935 Wire Wheel Backspacing and offset
Can some please tell me what those dimension are?
Thank you, Joe
jrvariel48 is offline   Reply With Quote
Old 08-28-2022, 08:18 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: 1935 Wire Wheel Backspacing and offset
I can't give you those dimensions right off the top of my head, but I CAN tell you that they will vary a few thousandths between each wheel. One size does not necessarily fit all, here.
WHOOPS: I read that to mean support spacers between the wheel and hub when using later drums with wire spoke wheels. My bad.
Old 08-28-2022, 10:46 PM   #3
Tinker
Tinker's Avatar
You talking model A to 35? or wire to 40s?
Old 08-29-2022, 03:24 AM   #4
V8COOPMAN
V8COOPMAN's Avatar
Not sure why folks want to confuse with answers to questions that they don't understand.
This is a "one-year-only", 1935 Ford 16" wire wheel.
"Re: 1935 Wire Wheel Backspacing and offset"
Simple questions:
What is BACKSPACING?
What is OFFSET?
Sorry Joe, that I don't have those figures, nor a wheel to measure such!
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 08-29-2022, 02:22 PM   #5
jrvariel48
jrvariel48's Avatar
Simple questions:
What is OFFSET?
Coop
Thanks Coop! Yes, that's exactly what I need!! anyone??
Old 08-29-2022, 02:30 PM   #6
tubman
tubman's Avatar
I have one loose in my shop. Do you still need the measurements?
Old 08-29-2022, 02:57 PM   #7
flatford8
flatford8's Avatar
I have a couple sets of what I think is in Coops picture.I’ll check in later to see if you got measurements……Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 08-29-2022, 06:03 PM   #8
flatford8
flatford8's Avatar
I come up with 3 1/8 backspace and 9/16 positive offset. Again, as long as these are the same wheels you’re talking about........Mark
File Type: jpg E3109CF1-06B8-400D-A1D9-1F8FD1A4CBF7.jpg (44.7 KB, 98 views)
Old 08-29-2022, 08:22 PM   #9
Don
Don's Avatar
I took some 3/16 rod !made a ring the size that fit the rim ,welded it togeather to form ring
then laid in in wheel,put a straight across the holes from one to the other then ground the ring to be flush with lug holes,,made a little clip to hold them in place when you put wheel on,,,I believe it helped some with the wiggle,I only needed them on front.
DON P
Don is offline   Reply With Quote
Old 08-30-2022, 02:16 AM   #10
jrvariel48
jrvariel48's Avatar
Yes I do!
Old 08-30-2022, 02:17 AM   #11
jrvariel48
jrvariel48's Avatar
Great, thank you!
Old 08-30-2022, 02:18 AM   #12
jrvariel48
jrvariel48's Avatar
Thanks, they look the same
Old 08-30-2022, 02:23 AM   #13
V8COOPMAN
V8COOPMAN's Avatar
SAME spoke count (32). Hubs APPEAR to be same. OUGHT to work!
Coop
T5 W/TORQUE TUBE
Old 08-30-2022, 02:45 AM   #14
jrvariel48
jrvariel48's Avatar
Coop
Excellent! Thank you!
