Old 05-26-2017, 04:31 PM   #1
Fibber Mcgee
Fibber Mcgee's Avatar
Default Best way to install fender welting?
I received my fender welting today from Roy Nacewicz (the good stuff). Is there a proper or best way to install? Do you need to cut slits for the curves and drill or punch the holes? The stuff I removed was the pvc junk and it was butchered.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 05-26-2017, 04:46 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Best way to install fender welting?
All the ones that I did including the stainless steel 'dress up' ones, I never drilled or punched holes.
Where each hole went I cut a suitable 'U' notch for the bolt locations and did 'V' and slice where required.
The holes were located with the fender off generally and then the welt was slipped in after the bolts were installed.
But that's up to personal preference.
Old 05-26-2017, 04:54 PM   #3
mountstimothy0
What about the ends? Would you fold them over or simply cut them off
Sent from my SAMSUNG-SM-J120A using Tapatalk
mountstimothy0 is offline   Reply With Quote
Old 05-26-2017, 05:02 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
That's where the slicing comes in.
Slice the flat as required to bend the bead and overlap the flats.
Old 05-26-2017, 06:29 PM   #5
Ken/Alabama
Ken/Alabama's Avatar
I always punch the holes with a hole punch. The fender bolts are 5/16 but I use a 3/8 punch, it gives a little wiggle room. At the ends I take a razor and cut the stitching back then cut the core then fold the sleeve at the end of the fender. On the curves you will need to make V cuts. I hate to see cars when they get to the bottom of the fender and the Welting is just cut straight off exposing the ends. But that's just me.
Old 05-26-2017, 07:21 PM   #6
Willit Stop
Willit Stop's Avatar
If you have a problem getting a snug fit,you can use masking tape about every 6 inches or so on the flap and pull the tape down as you go.
Cold beer and a radio helps too.
Willit Stop is offline   Reply With Quote
Old 05-26-2017, 10:20 PM   #7
fordor41
fordor41's Avatar
I glue(contact cement) the welting to the body after punching the holes. that way I can pull it tight, hole to hole. strip the welting back as above, fold the end over and glue. Then install the smallest pop rivet I can find to keep the ends in place. some welting tends to shrink in time and the rivet holds it real good.
fordor41 is offline   Reply With Quote
Old 05-27-2017, 02:48 PM   #8
Fibber Mcgee
Good information, thanks, looks like I have my weekend project now.
Old 05-24-2022, 05:59 AM   #9
ms fowler
I see another "brother from a different mother"
"Cold beer and a radio", indeed! If only my Orioles were worth listening to on that radio.....instead, it'll have to be "oldies radio" even though its not quite old enough. West Coast IPA is great; not everything in life is meant to be sweet--enjoy the bitter, too.
ms fowler is offline   Reply With Quote
Old 05-24-2022, 12:06 PM   #10
19Fordy
19Fordy's Avatar
With the fenders and bolts installed loosely,cut V-notches in the welting and slip it in and down into position. Then go back and snug up each fender bolt as needed.
Cut and fold over the webbing flange so it is held in place between the body and the fender.
Old 05-25-2022, 07:32 AM   #11
rotorwrench
rotorwrench's Avatar
Commenting on old threads with no questions can be confusing. Some of the original folks that posted may not even be around anymore.
rotorwrench is online now   Reply With Quote
Old 05-25-2022, 08:10 AM   #12
nelsb01
nelsb01's Avatar
Since this thread was re-started..............
Did anyone ever notice the small holes along the fender edge where the welting goes? These holes are about 1/16 dia.
I believe I heard it from a very knowledgeable man -- but those holes were where the welting was nailed on to the fender.
Think about this..... you and I wlll spend hours getting our fender welting installed -- but how long did it take on the original assembly line?
nelsb01 is offline   Reply With Quote
Old 05-25-2022, 09:21 AM   #13
19Fordy
19Fordy's Avatar
A Google Search provides lots of information on several techniques used to install fender welting:
https://www.google.com/search?q=how+...hrome&ie=UTF-8
Old 05-25-2022, 09:27 AM   #14
19Fordy
19Fordy's Avatar
nelsbno1: I never noticed any 1/16 in. holes along the fender edge of a 1940 Ford and would be very surprised if Henry Ford took the time to have a worker
manually "nailing" fender welt to a fender. It's too time consuming and labor intensive. More info. to verify what was told to you by a very knowledgaeable man would be great.
When I removed the original factory fender welting from my 40 Ford in 1972 I don't recall there being any nails holding it in place.
Old 05-25-2022, 09:38 AM   #15
nelsb01
nelsb01's Avatar
Time wise.......it would allow fender attachment and fender welting to be almost a single step process. No pulling on the welting to get it placed correctly. Think about it -- if the welting was attached at fender assembly, the process would be faster. Like I said, when we attach fenders, we spend hours aligning and fitting -- not so during Ford assembly.
That knowledgeable man has left us and it was too soon -- so going back to get more informantion is not possible.
Old 05-25-2022, 10:12 AM   #16
19Fordy
19Fordy's Avatar
Thanks for the reply about the welting. Sorry to hear the gentleman has passed. I am sure he was a wealth of knowledge from life's experience. Just imagine the amount of knowledge about our hobby that just fades away because it's not recorded.
Old 05-25-2022, 10:25 AM   #17
nelsb01
nelsb01's Avatar
I totally agree -- some of the best people have left us with many more questions to ask.
Always thought that if I ever got asked "If you could go back in time, where and when would it be?" I know that Ford in Dearborn would be one of my choices.
Old 05-25-2022, 11:50 AM   #18
Kube
Super Moderator
Kube's Avatar
I can't speak to any years other than '39 and '40. In those years, depending on model and placement, some pieces of the welt were in fact nailed to the sheet metal and in others, they were stapled.
When judging, I look for this in some areas.
You are correct in your assumption that this was done for efficiency (IE cost savings). The process was rather quick. The holes you'd mentioned were created during the process. Thus, no "alignment" for a workman.
Old 05-25-2022, 01:39 PM   #19
Ben38
Ben38's Avatar
When I took my car apart 40+ years ago, the fender welt was attached with spiral shank nails. I remember wondering how they drove the nails through the metal
Ben38 is offline   Reply With Quote
Old 05-25-2022, 02:31 PM   #20
19Fordy
19Fordy's Avatar
OOPS! I just learned something new about welting.
Thank you all for posting.
JIM
