Old 05-17-2022, 03:49 PM   #1
Fatheads4ever
Fatheads4ever's Avatar
Default Gearbox growls in top gear only when I hold over the stick when driving down the road
I overhauled the 3 speed 1946 p/u box with new bearings and second gear and synchro cones etc. All looked snazzy. What could be causing the noise? It occurs only if I lean on the gear lever when driving in top.
Any ideas anyone?
Thanks Kevin
Fatheads4ever is offline   Reply With Quote
Old 05-17-2022, 04:50 PM   #2
cas3
Default Re: Gearbox growls in top gear only when I hold over the stick when driving down the
Well. thats easy, don't lean on the lever ! but really, when leaning, you are putting side thrust and forced contact on the fork and synchro hub , so perhaps one or the other has a rough surface ?
Old 05-17-2022, 06:01 PM   #3
Fatheads4ever
Thanks cas3.. I'm kinda hoping that it might go away over time.
Old 05-17-2022, 06:25 PM   #4
B-O-B
B-O-B's Avatar
It is a shift lever not a hand rest. Save that for the steering wheel or you G F
B-O-B is offline   Reply With Quote
Old 05-17-2022, 06:27 PM   #5
rotorwrench
rotorwrench's Avatar
The Synchro sleeve has a sweet spot that it likes to rotate in. Applying pressure to the sleeve through the gear change mechanism has a tendency to force the sleeve out of that sweet spot. The gear selector is not really a good place to rest your arm.
