Old 04-30-2022, 07:10 AM   #1
olfarmer
Default Mercury crankshaft
Working on a 8BA found three of the four plugs you drive in the crankshaft was in the oil pan. I have threaded the holes with 3/8 NPT tap. My question is would you install aluminum or steel Allen headed plugs? The steel plugs weigh about 132 grains and the aluminum plugs weigh 64 grains.
Thanks in advance for your help and advice.
olfarmer is offline   Reply With Quote
Old 04-30-2022, 07:46 AM   #2
cadillac512
cadillac512's Avatar
Default Re: Mercury crankshaft
I'd use the plugs closest in weight to the originals. Likely aluminum.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 04-30-2022, 10:12 AM   #3
Ol' Ron
Ol' Ron's Avatar
Aluminum , closer to the original plugs.
Gramps
Old 04-30-2022, 02:15 PM   #4
hotrodart
hotrodart's Avatar
Maybe use some thread-locker to keep them from falling into the oil pan again.....
hotrodart is offline   Reply With Quote
