Old 02-14-2022, 09:44 AM   #1
Shoebox
Shoebox's Avatar
Default High temp coatings
I recently acquired a really nice pair of original Fenton headers (Thank You 40fords!). Just had them lightly media blasted and will be painting them gloss or flat black. Now I know that there are a ton of high temp products around these days, in my youth the go-to brand was VHT, maybe still is. Anyhow, there are other brands, ceramic varieties, and so forth. Just wondering if there are any recommendations for a product RECENTLY used by someone. I also see some high temp primers offered, important to use? On my '32 Highboy roadster with an open engine compartment, I had the headers ceramic powder coated and they have held up great, but I am kinda looking for a rattle can solution here. Thanks guys.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is online now   Reply With Quote
Old 02-14-2022, 12:18 PM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: High temp coatings
Check out the Cerakote website - for their high-temp ceramic coatings. I've used them for headers on a variety of race and street cars. The key is for the media blasting to be done correctly (and don't touch the material with your bare hand) - and then put them in a BBQ and bake the coatings on at about 500 degrees. Once you do this, the stuff is pretty darn tough.
https://www.cerakote.com/shop?msclki...ontent=General
Old 02-14-2022, 12:22 PM   #3
Shoebox
Shoebox's Avatar
Thanks Dale,
Will look into cerakote.
32 Ford roadster
39 Mercury Towncar
Old 02-14-2022, 12:24 PM   #4
Bored&Stroked
Here are the last ones I did for my 32 Cab:
Old 02-14-2022, 01:33 PM   #5
swedishsteel
I've used the Rustoleum High Temp paints on the exhaust manifolds in our "55 tbird and '67 mustang and the Red's headers in my '36 coupe- very pleased, especially on the cast manifolds that like to bleed rust even after sandblasting. The tbird manifolds are several years old and still look like I just painted them. Use the primer and follow the curing directions.
swedishsteel is offline   Reply With Quote
Old 02-14-2022, 02:07 PM   #6
Shoebox
Shoebox's Avatar
Attachment 484288
That looks real good. Are those bungs on the head pipes for A/F sensors?
32 Ford roadster
39 Mercury Towncar
Old 02-14-2022, 02:09 PM   #7
Shoebox
Shoebox's Avatar
Thanks Swedish,
I am looking at several products including the Rustoleum line.
32 Ford roadster
39 Mercury Towncar
Old 02-14-2022, 04:23 PM   #8
Bored&Stroked
No, those are for EGTs (which is why they are as close to the port as possible). I have O2 sensor bungs in the pipes that bolt to these headers (with gaskets). It is important that there are no oxygen leaks before the O2 bungs - which is yet another reason to add flanges to the "Belond Style" headers that everybody seems to make. Also, you want the O2 bungs at least about 2 feet back from the ports.
Having both O2's and EGTs gives me what I need to tune the carbs. I use the O2's the most as I'm not running these on a boosted engine (where EGTs become all the more important).
Old 02-14-2022, 04:30 PM   #9
petehoovie
petehoovie's Avatar
Attachment 484288
Old 02-15-2022, 12:06 AM   #10
Tinker
Tinker's Avatar
I hate to be this guy... but whatever paint you use will burn off. Most exhaust manifolds will see up to 500 degrees over time repetitively. It will break down. They might hold up for a bit.
Paint them with a good paint but don't be surprised in a yr or two if it's gone.
The fentons will still be cool!
Old 02-15-2022, 09:27 AM   #11
swedishsteel
The High Temperature Rustoleum won't. We have a '55 T bird with the original cast iron manifolds--sand blasted and primed and painted with the High temp paint six years ago. We drive it quite a bit and those manifolds still look like new.
Old 02-15-2022, 09:22 PM   #12
52flthed
I’m using Jet Hot in North Carolina to coat my exhaust manifolds. The advantage is that it’s a thinner coating so it isn’t likely to crack off. It comes with a lifetime guarantee. From what I’ve been able to gather it’s superior to cerakote. The POR product I tried didn’t work rust stains one month later.
52flthed is offline   Reply With Quote
Old 02-15-2022, 10:47 PM   #13
fordor41
fordor41's Avatar
I used gray VHT on my C.I. manifolds and it lasted years
fordor41 is offline   Reply With Quote
Old 02-17-2022, 07:24 AM   #14
flatmotor40
flatmotor40's Avatar
My tube headers are coming back tomorrow from Jet-Hot had they done at the place in Ga but they started to peel so I sent them to Jet-Hot.They are set of total tube headers with a 3 inch collector and I don't want them to rust out.Trying to remember the guy in Oregon that just passed away did them.A flathead man.I'll think of his name later.I've tried all kinds of paint on my other cars and nothing holds up
flatmotor40 is offline   Reply With Quote
Old 02-17-2022, 07:29 AM   #15
flatmotor40
His name was Dave Tatum
Old 02-20-2022, 11:33 AM   #16
flatmotor40
can't download the pic of my headers by pushing attachment or insert image it says jpg failed.Just download 11 maybe go back to 10.Not good with computer Thanks for help
Old 02-20-2022, 01:07 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
That message is likely telling you that the "jpg" image is too large for a FordBarn download. If you e-mail that picture to yourself and then use the 'NEW' e-mailed image (save the new image to your computer), I'd bet a quarter that it will post! PLEASE let us know how that works-out! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-21-2022, 07:30 AM   #18
flatmotor40
I"ll try but as I said I don't fool with computers too much need my niece here to help me
Old 02-21-2022, 08:42 AM   #19
PeterC
PeterC's Avatar
Default Re: High temp coatings - Porcelain
[QUOTE=Tinker;2104808]I hate to be this guy... but whatever paint you use will burn off. Most exhaust manifolds will see up to 500 degrees over time repetitively. It will break down. They might hold up for a bit.
When I was building my former 35 Coupe I know I was certified insane and "over the top" in my approach ... I just followed the leaders back in the 30's like Rolls Royce, Cadillac and Duesenberg and had my Fentons finished in black Porcelain. Five years+ and not a flaw in the finish.
PeterC is offline   Reply With Quote
Old 02-21-2022, 09:53 AM   #20
flatmotor40
try it again
