Old 02-15-2022, 01:14 PM   #1
alanwoodieman
Default piece of machinery
anybody have an idea what this may be? it came out of an engine builders shop, only numbers on it are 3198 and 1E
Old 02-15-2022, 01:39 PM   #2
Ggmac
Default Re: piece of machinery
Looks similar to a can edge roller or cutter . The ones I remember could roll a can lid and seal it , used mostly for canning food . This is much larger .
Old 02-15-2022, 01:41 PM   #3
flatford8
flatford8's Avatar
That's the same idea I had, or cutting strips of sheet metal........Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 02-15-2022, 01:46 PM   #4
rockfla
rockfla's Avatar
Its a capitchulator pin remover for a loafing bolt!!!
Old 02-15-2022, 02:11 PM   #5
petehoovie
petehoovie's Avatar
Old 02-15-2022, 03:10 PM   #6
woodiewagon46
I think that the round peg with the set screw is a stop for measuring the distance from the cutting wheel, turned by the crank handle. It might be for cutting strips of something. I don't think sheet metal though, I'm leaning towards cardboard, linoleum or some other material.
woodiewagon46 is offline   Reply With Quote
Old 02-15-2022, 03:16 PM   #7
petehoovie
petehoovie's Avatar
Nailed it!!!
Old 02-15-2022, 03:57 PM   #8
Mart
Mart's Avatar
I think it is a circle cutter.
You set the sliding piece to the radius and the wheel will cut a circle out of sheet metal.
Mart.
Edit: I'm not sure after googling images of vintage circle cutters. There's a subtle difference.
Old 02-15-2022, 04:37 PM   #9
deuce_roadster
deuce_roadster's Avatar
Circle cutter for gasket material or rubber is my guess.
Old 02-15-2022, 04:50 PM   #10
alanwoodieman
it is either a whatchamecallit or widgett adjust for a lazy guy
Old 02-15-2022, 04:56 PM   #11
ford38v8
ford38v8's Avatar
You’re all wrong. It’s an apple peeler.
Alan
ford38v8 is online now   Reply With Quote
Old 02-15-2022, 05:05 PM   #12
Lanny
Lanny's Avatar
You put a grinder disc on it, that has a center hole in it.
Put the disc on that stud and move the stud toward
the cutting wheel, and trim the wore out edge off the
grinding disc, it's ready to grind some more.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 02-15-2022, 05:09 PM   #13
51 MERC-CT
51 MERC-CT's Avatar
It's an auto body grinding disc trimmer used to remove outer bad/worn portion of disc to freshen up the disc and give longer life to the disc.
(the center pin should be 7/8" dia.)
Old 02-15-2022, 06:02 PM   #14
deuce5wndw
deuce5wndw's Avatar
Lanny and 51 MERC nailed it. I've got one and it works like a charm.
deuce5wndw is offline   Reply With Quote
Old 02-16-2022, 02:25 AM   #15
T Scott
Don't go near it! It's a manual circumcision machine!!
T Scott is offline   Reply With Quote
Old 02-16-2022, 09:50 AM   #16
Lawson Cox
Lawson Cox's Avatar
Originally Posted by t scott View Post
don't go near it! It's a manual circumcision machine!!
roflmao
Old 02-16-2022, 10:26 AM   #17
OldGold360
Gross! I was going to offer to buy it... I think I'll pass now.
OldGold360 is offline   Reply With Quote
Old 02-16-2022, 03:06 PM   #18
Mart
Mart's Avatar
You're saying there are POWER ones??
Old 02-16-2022, 03:09 PM   #19
B-O-B
B-O-B's Avatar
That's it .I understand it once you explained it, I see where the disc fits over the stud sticking up & you can measure how much you wish to cut off. Jeez that was easy & any one can see that.
B-O-B is offline   Reply With Quote
Old 02-16-2022, 03:39 PM   #20
petehoovie
petehoovie's Avatar
Other variations >
