anybody have an idea what this may be? it came out of an engine builders shop, only numbers on it are 3198 and 1E
Looks similar to a can edge roller or cutter . The ones I remember could roll a can lid and seal it , used mostly for canning food . This is much larger .
That's the same idea I had, or cutting strips of sheet metal........Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
Its a capitchulator pin remover for a loafing bolt!!!
Nailed it!!!
I think it is a circle cutter.
You set the sliding piece to the radius and the wheel will cut a circle out of sheet metal. Mart. Edit: I'm not sure after googling images of vintage circle cutters. There's a subtle difference. Last edited by Mart; 02-15-2022 at 04:03 PM. |
Circle cutter for gasket material or rubber is my guess.
it is either a whatchamecallit or widgett adjust for a lazy guy
You’re all wrong. It’s an apple peeler.
Alan |
You put a grinder disc on it, that has a center hole in it.
Put the disc on that stud and move the stud toward the cutting wheel, and trim the wore out edge off the grinding disc, it's ready to grind some more. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I got the rear-end put in the recliner, and now I'm going to rest up & watch TV.
#13 |
It's an auto body grinding disc trimmer used to remove outer bad/worn portion of disc to freshen up the disc and give longer life to the disc.
(the center pin should be 7/8" dia.)
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 02-15-2022 at 05:18 PM. |
#14 |
Lanny and 51 MERC nailed it. I've got one and it works like a charm.
#15 |
Don't go near it! It's a manual circumcision machine!!
#16 |
#17 |
#18 |
#19 |
That's it .I understand it once you explained it, I see where the disc fits over the stud sticking up & you can measure how much you wish to cut off. Jeez that was easy & any one can see that.
#20 |
Other variations >
