Old 01-29-2022, 12:11 AM   #1
48fordnut
48fordnut's Avatar
Default solenoid with start button
Anyone know what brand, or where to get a ford starter solenoid with the button on the bottom for bumping the eng over?
Thanks,
jim
48fordnut is offline   Reply With Quote
Old 01-29-2022, 12:15 AM   #2
Tinker
Tinker's Avatar
Default Re: solenoid with start button
There is a few floating and sitting in drawers somewhere. You can always hop the soleniod with screwdriver in a pinch.
Quick google search. Don't like the look of this one personally.
https://www.cjponyparts.com/starter-...oaAnMDEALw_wcB
Old 01-29-2022, 01:17 AM   #3
petehoovie
petehoovie's Avatar
Dennis Carpenter > https://www.dennis-carpenter.com/car...olenoid-switch
Starter Solenoid - 1937-51 Ford Truck, 1937-48 Ford Car
Part #: 01A-11450
Features:
• Metal Casing with Ford Script
• With push button for under hood starting
• 6 Volt - mounts on firewall
Old 01-29-2022, 01:52 AM   #4
leon bee
My NAPA can get em in one day, Echlin. Part# should be on their website.
leon bee is offline   Reply With Quote
Old 01-29-2022, 02:03 AM   #5
leon bee
I guess it's their ECH ST53.
Old 01-29-2022, 10:36 AM   #6
Big Red 51
Big Red 51's Avatar
Leon, I think the ST 58 is for Negative ground only. ST 53 is the one for Positive ground. I found this out the hard way when NAPA thru the wrong one in the bag when I needed one (ST53) for positive ground on '49 PU. Of course I couldn't return it. The ST58 was made for some small Nash/AMC cars that were 6 Volt. 58 was made in Asia and 53 was made in Mexico with no ST number stamped on them only 6V, back in June 2020.
Don
Last edited by Big Red 51; 02-01-2022 at 04:21 AM. Reason: Typed wrong solenoid number for Echlin solenoid.
Big Red 51 is offline   Reply With Quote
Old 01-29-2022, 11:35 AM   #7
1931 flamingo
1931 flamingo's Avatar
Joe's Antique, C&G to name a few.
I got one at NAPPA (Echline?), no good.
FWIW
Paul in CT
Old 01-29-2022, 11:44 AM   #8
Pech33
Pech33's Avatar
Make sure you take it out of gear before you push the button. Scare the crap out of you if you don't!
Pech33 is offline   Reply With Quote
Old 01-29-2022, 11:58 AM   #9
tubman
tubman's Avatar
Originally Posted by Big Red 51 View Post
Leon, I think the ST 53 is for Negative ground only.
Don
I don't think solenoids are polarity sensitive.
Old 01-29-2022, 12:03 PM   #10
GB SISSON
GB SISSON's Avatar
I think some make their connection when the small wire is negative, and the others when the small wire is positive. I'm no electrician, just my observation when testing them.
Old 01-29-2022, 01:13 PM   #11
drolston
drolston's Avatar
One of the handiest tools around my garage is the remote starter button, which clips to the terminals of the starter solenoid. Like to chank the engine while checking for a spark from coil or plug wire. Or running a compression test. Or testing for fuel pump output. Better than the solenoid with a button, because you can activate it from any place around the front end.
Old 01-29-2022, 01:46 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
I surely can NOT imagine any reason why a solenoid would be polarity sensitive. That coil is only wanting to complete a circuit. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-29-2022, 02:31 PM   #13
JayChicago
JayChicago's Avatar
Doesn't the pull-in coil need the electrons flowing in the correct direction to make the magnetic action pull the correct way? If polarity reversed, wouldn't the coil try to pull the other way?
EDIT:
Just thought of something: My wash machine uses solenoid water valves, and its running on alternating current, electrons flowing both ways. So I guess a solenoid coil does not care about positive/negative.
Old 01-29-2022, 03:02 PM   #14
Tim Ayers
6 or 12V? If 6V, I have a brand new Standard in the box that I can get the part number off of if you're interested. It has the starting button
Old 01-29-2022, 04:56 PM   #15
cas3
I use an original ford unit, now on 12v neg ground, works fine. I did learn though, they need to be mounted so that gravity can not help hold the circuit closed or they will stick on occasionally.
Old 01-29-2022, 05:16 PM   #16
Lawson Cox
Lawson Cox's Avatar
Yeah, he "mechanic's button" goes on the bottom.
Old 01-29-2022, 05:34 PM   #17
cas3
Correct Lawson !
Old 01-29-2022, 06:46 PM   #18
koates
The starter solenoids we use in our old cars will certainly work for both negative ground or positive ground. Some types however have differing internal connections for different wiring hook ups. The two types shown in posts #2 & #3 are the early Ford type with the button which are normally mounted with the button underneath, but would work in any position. Pity some incorrect information has already been posted on here, Regards, Kevin.
koates is offline   Reply With Quote
Old 01-29-2022, 08:17 PM   #19
GB SISSON
GB SISSON's Avatar
Well, this is quite timely for me. About 5 minutes ago I had made up the battery cables and put a 12v battery (and negative grounded)in my newly fabricated battery tray. I had the solenoid with a button (looks like a repro style of original) mounted to the firewall. The small terminal on the solenoid is labled 'battery'. I jumpered a hot wire from the battery positive terminal to that small post and nothing. I then jumped a wire from the grounded chassis and off she spun. I know very little of electrons and such so it is all trial and error with me. I guess I will keep it this way.
Old 01-29-2022, 08:39 PM   #20
koates
GB, Yes all the early Ford V8 solenoids require the small terminal to be grounded through the starter button to the metal on the dash panel. Yours is correct for a Ford V8. There are many other types of wiring hook up solenoid types with different terminals. Regards, Kevin.
