Old 12-20-2021, 10:29 AM   #1
Bill Goddard
Bill Goddard's Avatar
Default Engine ticking noise
My engine has a ticking noise that increases with rpm and can be heard at idle when stopped. I think it is a valve clearance noise. If it is valve noise is it normal? I have heard it on some other A's but not all. Thanks, Bill G
Bill Goddard is offline   Reply With Quote
Old 12-20-2021, 11:36 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Engine ticking noise
Try to locate the noise. If its coming from the valve cover its probably valve lash. Removing the cover will allow for checking the lash and determining if you have non-adjustable or adjustable lifters. [ manifolds don't have to be removed for this.]
Is the noise normal ? Yep, that is, a certain amount is normal.
Old 12-20-2021, 11:53 AM   #3
TerryH
TerryH's Avatar
You might also want to check your timing gear. Mine started making a slight noise before it let go….
TerryH is offline   Reply With Quote
Old 12-20-2021, 12:20 PM   #4
Fullraceflathead
Fullraceflathead's Avatar
Sometimes a valve will start sticking in these engines due to varnish from old fuel because the spring tensions are very low compared to an overhead valve engine doesn't take much for the valve to stick
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 12-20-2021, 05:23 PM   #5
WHN
Please don’t start taking things apart.
Marvel Mystery Oil in your gas should help you out.
If you have a higher mileage engine you might also want to change your old to 20W-50 along with one blue bottle of STP as the last half quart.
This is my standard first advise on what you have said your car is doing. In most cases that I am aware of, it has done the trick. Good luck.
Enjoy.
Old 12-20-2021, 06:47 PM   #6
nkaminar
nkaminar's Avatar
Ticking noise can some from a variety of sources. Excess valve clearance, sticking valves, cam moving, cam gear loose, loose rod bearings, distributor shaft binding, knocking due to timing too advanced, worn timing gear, more. If you can, take a video and publish it here. Does the ticking go away when you retard the ignition? It is louder under load, under no load, during decelerating, when the engine is cold or warm? The more information the better we will be able to help.
Old 12-20-2021, 07:20 PM   #7
1crosscut
1crosscut's Avatar
Buy a mechanics stethoscope and see if you can narrow it down a bit as to where it is coming from.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 12-20-2021, 07:50 PM   #8
Mad Mac
My ticking noise turned out to be a blown manifold gasket
Mad Mac is offline   Reply With Quote
Old 12-23-2021, 01:53 PM   #9
Bill Goddard
I will check these things this weekend. Thanks
