Old 12-19-2021, 04:58 PM   #1
Crownir1
Default 1932 body webbing
I have a 1932 ford which the body and fenders were all removed before I purchased the car. I realize that webbing needs to be placed on the frame under the body.
Does webbing also go under the firewall? At the factory the firewall was attached to the frame before the body was was mounted?
Does webbing also go on top of the frame and under the front fenders? At the factory the front fenders where mounted after the firewall and the body?
Does it make sense that the body webbing was installed when the body was mounted to the frame and thus was placed only under the body and not under firewall and front fenders?
Thanks for the help.
Crownir1 is offline   Reply With Quote
Old 12-19-2021, 05:54 PM   #2
DavidG
DavidG's Avatar
Default Re: 1932 body webbing
The same webbing (1/16" x 2") was used under the body (part way) and under the front fenders. The piece for under the left front fender was notched near the rear on the inside so that the engine number stamped on the frame wasn't covered up. Small separate pads were used under the firewall where it attached to the frame in two places on each side. Those small pieces were also 1/16" thick, but sometimes two pads per location are encountered, increasing their width to 1/8"
The pieces under the body itself only run to the start of the kickup in the frame to clear the rear axle, but short of the last body-to-frame attachment before the kickup. The two remaining body-to-frame attachment points rearward on each side had fabric-reinforced rubber pads rather than webbing. The rearmost of those was 1/4" thick and the one further forward was 1/8" thick.
Caution must be exercised when making the two rearmost pads. If the back side of the pad is too far back you will not be able to install the gas tank in its original position as the forward lip on the tank will conflict with an oversized pad.
The body-to-frame webbing was originally installed with metal grommets attaching it to the top of the frame rails to hold it in place for the body drop, but two-sided tape is a good modern substitute.
