Or the ID of the hole in the manifold for the road draft tube ?
Looks like 1 5/8" or so? Thanks. |
#2 | |
Not sure the exact dimension, but if you're possibly looking for a way to block it off for a PCV Valve mod, a Dorman #555-023 freeze plug is a perfect fit. Link to the thread if you're interested. DD https://www.fordbarn.com/forum/showt...pman+pcv+valve . |
I believe he is asking about the size of the exterior tube on an 8BA type manifold.
Are they the same? |
#4 | |
Tub is correct.....and I blew it once again! DD |
It is 1 1/4" where it enters intake.
Do you need the tube?
'52 F-1, EAB flathead |
Naw. When the engine gets back from H&H I'm going to install a ME Wagner PCV valve on it........ I refuse to buy an aluminum plug for $40 (Jamco) when I can machine a remnant piece of 6061 in 5 minutes.
#9 | |
Karl |
