Old 11-05-2021, 06:47 PM   #1
Lee29coupe
Default Fried rear bearing
My engine seized up and it looks like my rear babbit went south on me. I’m pulling the oil pan in the morning to see but it looks like it will need new babbit for it so will do all of them. Any experience on putting inserts in instead of poured babbit. Either way any recommendations on a good shop to do either babbit or insert? In the mid Atlantic area.
Lee29coupe is offline   Reply With Quote
Old 11-06-2021, 09:56 AM   #2
History
History's Avatar
Default Re: Fried rear bearing
I know a fellow who does the inserts but he is pretty loaded up with work. He's close to Mt Airy NC. I know he's an excellent mechanic and will probably do mine when I have it done. Message me if you're interested and I'll give you his info.
History is offline   Reply With Quote
Old 11-06-2021, 10:50 AM   #3
nkaminar
nkaminar's Avatar
If you are lucky only the cap will be damaged and you can buy a new cap, and a lottery ticket.
Old 11-06-2021, 04:29 PM   #4
Synchro909
Synchro909's Avatar
IMO, you should think carefully about using inserts. It seems Rich Falluca (spelling?) is trying to sell that part of his business but so far, no takers. There is absolutely no guarantee that the inserts will be available into the future.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 11-06-2021, 04:32 PM   #5
Fhane
Fhane's Avatar
Maybe if you shared your location.
Fhane is offline   Reply With Quote
Old 11-06-2021, 04:56 PM   #6
chrs1961815
chrs1961815's Avatar
Rich sold his business to a guy who already does engines and they are in the process of training. But they are not doing any new work.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 11-06-2021, 07:17 PM   #7
Synchro909
Synchro909's Avatar
I believe Rich sold the engine rebuilding part of the business but not the parts component of it which is where the inserts were handled.
Old 11-07-2021, 07:03 AM   #8
chrs1961815
Actually the parts business was part of it. It looks like it is going to turn out good.
Old 11-07-2021, 08:28 AM   #9
Fhane
Fhane's Avatar
Search SCHWALMS.COM Located in Strasburg, PA. About 40 miles from you.
Old 11-07-2021, 11:35 AM   #10
1crosscut
1crosscut's Avatar
Lee, what did you find when you pulled the pan?
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 11-07-2021, 03:41 PM   #11
Synchro909
Synchro909's Avatar
I certainly hope you are right.
Old 11-07-2021, 04:26 PM   #12
Jeff/Illinois
Jeff/Illinois's Avatar
Definitely Schwalms, they are who you want to contact. They do some excellent work. And you are close.
Old 11-10-2021, 01:17 PM   #13
Colonial coupe
Schwams. He had a nice assortment of rebuilt shortblocks at Hershey for what I thought were very reasonable prices. His work shows pride and craftsmanship. Nice guy, on Wednesday I had a chance to talk with him early before it got busy, I plan on getting one of those beauties next year.
Colonial coupe is offline   Reply With Quote
Old 11-10-2021, 02:55 PM   #14
AL in NY
AL in NY's Avatar
You may want to consider the new Model A engine designed and sold by Terry Burtz. His block doesn't include the valve train, but it is a brand new engine. I would seriously consider that option.
AL in NY
AL in NY is offline   Reply With Quote
Old 12-30-2021, 07:31 AM   #15
Lee29coupe
Pulled engine and beat up solenoid bolt and a chunk of pedals stop fell out of bell housing. Engine now turns over, must have been jammed up in flywheel. Time to turn lemons into lemonade and check valve and crank shaft clearance, clean out oil pan, and touch up engine compartment. Thanks for all the advice.
Old 12-30-2021, 10:28 AM   #16
Planojc
Planojc's Avatar
Time to buy that lottery ticket.
Planojc is offline   Reply With Quote
Old 12-30-2021, 09:16 PM   #17
nkaminar
nkaminar's Avatar
I am a little bit confused on how that stuff can get in the bell housing. I am happy that the fix was that simple.
Old 12-31-2021, 07:06 AM   #18
Lee29coupe
I think previous owner may have placed pedal part on top of bell housing with clutch bearing cover removed and fell into housing. Starter solenoid bolt is infamous for coming lose or breaking and getting caught while bouncing around bell housing. Either way better than what it could have been.
Old 12-31-2021, 07:29 PM   #19
TerryO
TerryO's Avatar
Solenoid bolt??? I think you meant to say bendix or starter drive bolt.
TOB
TerryO is offline   Reply With Quote
Old 01-02-2022, 07:52 PM   #20
Lee29coupe
You are right , bendix bolt. Either way better than what is sounded like!
