Old 10-22-2021, 01:48 PM   #1
Fatheads4ever
Fatheads4ever's Avatar
Default Valve seat inserts.
Hi all.. would any happen to know the size of the valve seat inserts in a c59a block. Some of mine are looking very wide after regrinding.
Thanks all in advance.
Fatheads4ever is offline   Reply With Quote
Old 10-22-2021, 02:03 PM   #2
bbrocksr
Default Re: Valve seat inserts.
Narrow them with a 30 and a 60 degree stone to about 3/32 .
Bill
bbrocksr is offline   Reply With Quote
Old 10-22-2021, 02:08 PM   #3
Ronnieroadster
Ronnieroadster's Avatar
Having had experience replacing Ford flathead V-8 valve seat inserts I learned one important thing. First remove the original seat ring and now determine if the opening in the block still round. I have found the openings in the block are no longer round just the results of age and so many heat cycles. If the opening is not round a stock replacement ring may be loose or become loose after installation. The interference dimension is so slight if the opening is not round there's a good possibility of the ring becoming loose. To correct this problem I always carefully increase the opening diameter until its round. Once I have the new opening ready for a seat i now order a replacement in the dimension i need. Tucker Valve Seat company can make to order seats.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 10-22-2021, 02:08 PM   #4
supereal
supereal's Avatar
That is a job for a machine shop. We recut the pockets and install hardened seats at our shop. The pockets must carefully examined for cracks. If the seats were replaced at sometime, that can be a problem if done improperly.
supereal is offline   Reply With Quote
Old 10-23-2021, 08:10 AM   #5
big job
big job's Avatar
Not darkside but then you do what you gotta do. Back before all these venders a lot of seats were simply ground into the block. So we would bore the block for a known size cast iron water pipe kike a ring and press that in and grind the valve angle. bottom line whats the difference cast iron block cast iron ring. Now with available seats you still have to bore the block .......got these pics in my computer that had heart attack lol maybe it can be fixed......sam
big job is offline   Reply With Quote
Old 10-24-2021, 05:57 PM   #6
Craig CT
Craig CT's Avatar
Ronnieroadster
Hi Ronnieroadster; How much OD do you add to the seat insert after the block has been prepped? Thanks Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain.
Craig CT is offline   Reply With Quote
Old 10-24-2021, 06:16 PM   #7
Pete
.006 for cast iron.
.007 for aluminum.
Old 10-24-2021, 07:44 PM   #8
Craig CT
Craig CT's Avatar
Originally Posted by Pete View Post
.006 for cast iron.
.007 for aluminum.
Hi Pete; Thank you, Craig.
Old 10-25-2021, 01:39 PM   #9
Ronnieroadster
When I place an order with Tucker I tell them the now round finished valve seat bore diameter in the block. From that information they then decide the proper additional amount needed for the new valve seats so they stay in place once I install them.
Ronnieroadster
Old 10-25-2021, 04:32 PM   #10
Karl Wolf
Karl Wolf's Avatar
I replaced all the valve seats in my 59AB.
Found washers that fit in the old seat, arc weld them in.
This shrinks them, they come out easily.
Measure the holes for size. Round, yes- but it's harder.
See if the aftermarket seats will do.
I had seats made, KO Lee, I think. Not a lot of $.
I made a driver from some cast iron plumbing fittings.
The tool uses the valve guide hole to keep the seat square as it's driven in.
Karl
Karl Wolf is offline   Reply With Quote
Old 10-25-2021, 05:55 PM   #11
Fatheads4ever
Thanks guys.. all good advice
Regards Kevin
Old 10-25-2021, 08:56 PM   #12
Craig CT
Craig CT's Avatar
Ronnieroadster
Hi Ronnieroadster; Thank you, Craig.
