Having sticky braking on my 49 with power brakes. Haven't taken it for a drive except for driving on the lift to work on it. What could be causing that?
41 woodie https://41fordwoodie.weebly.com/ |
#2 | |
What are the symptoms that you are calling "Sticky Braking"? . |
If the shoes are not retracting, or retracting slowly, could be the flexible brake hose going to the wheel cylinders (front). With age they can collapse internally and act like a one-way valve.
If I tap the brakes lightly they might lock up
Disc front on fat man front end, drum rears on Ford 8 inch rear end.
Piston in master cylinder not returning far enough to uncover port in master will lock them up. When they are locked if you crack a bleeder does that unlock them
#9 | |
I believe he is saying that just a short, light pressure on pedal CAN lock 'em up! DD . |
