Old 09-04-2021, 08:35 PM   #1
46woodie
Default Erratic speedo up to about 30mph
Speedo on my 46 is pretty erratic up to about 30-40mph. The cable gos through a gear changer for my Columbia then to my speedo. Any suggestions why I cant get steady reading while driving?thanks
46woodie is offline   Reply With Quote
Old 09-04-2021, 10:05 PM   #2
cas3
Default Re: Erratic speedo up to about 30mph
Either the cable is dry, needs grease, or its not routed correctly, needs smoother less kinky corners
Old 09-04-2021, 10:32 PM   #3
46woodie
Thanks,will lube tomorrow
Old 09-05-2021, 11:31 AM   #4
glennpm
glennpm's Avatar
Disassemble the Columbia supplied Stewart Warner speedometer "transmission" while you're at it.
Old 09-06-2021, 09:47 PM   #5
Royal Ryser
cas3, what do you lubricate the cable with?
Royal Ryser is offline   Reply With Quote
Old 09-06-2021, 10:21 PM   #6
cas3
You can buy actual speedo grease intended for this, but I just use a lithium based grease. Not the white stuff, it tends to dry up and get hard over time.
Old 09-07-2021, 04:50 AM   #7
Mart
Mart's Avatar
I oiled a speedo cable once, and it did not help. I then greased it and it did help. I think the grease acts as a damper of sorts and damps down the fast/slow action.
The fast/slow action is normally generated at a kink in the cable so check the routing. Also check it is not close to the exhaust at any point.
Mart.
Old 09-07-2021, 01:04 PM   #8
4dFord/SC
4dFord/SC's Avatar
Just a tip. When you disconnect the cable from the speedometer, immediately cover the end with a plastic baggy or some such. Those things tend to have a mind of their own and can leave skid marks on your kick panel and/or upholstery when you're pulling them out. No need to ask how I know.
4dFord/SC is offline   Reply With Quote
