Old 08-01-2021, 09:35 PM   #621
V8COOPMAN
V8COOPMAN's Avatar
Default Re: photo1-1-window
40 v8
Click Links Below __
T5 W/TORQUE TUBE
Old 08-02-2021, 09:51 AM   #622
V8COOPMAN
V8COOPMAN's Avatar
Raised Deck
T5 W/TORQUE TUBE
Old 08-02-2021, 12:24 PM   #623
V8COOPMAN
V8COOPMAN's Avatar
REAR BACKING PLATES
LATE STYLE '42-'48
T5 W/TORQUE TUBE
Old 08-02-2021, 01:13 PM   #624
V8COOPMAN
V8COOPMAN's Avatar
Spindle
T5 W/TORQUE TUBE
Old 08-02-2021, 01:51 PM   #625
V8COOPMAN
V8COOPMAN's Avatar
1941 STEERING-Running Differences
__________________________________________________ ________
LATE '41
T5 W/TORQUE TUBE
Old 08-02-2021, 04:02 PM   #626
V8COOPMAN
V8COOPMAN's Avatar
Lawson .....Not unlike "51-Merc..." here, I've GOT to make a comment or two. Highest on the list, and once again for you......POSTING PICTURES HERE AIN'T HARD!! Myself, as well as MANY others, have been posting photos here for years, and it is no harder to post a picture than it is to suck a sip of beer.
Ya know, a few years back, a bunch of folks asked Ryan to change the format over on the H.A.M.B. And yeah, it's a little easier to post pics over there now, but SOOO much more changed with the new format, and it affected ME so negatively that I haven't been back since.........but that's MY particular problem! I pray that Ryan leaves this alone here...........IT'S WONDERFUL as-is!
You should note that "tubman" is one of our more-knowledgeable and most-generous members with sharing his wisdom. He is also quite active with sharing pictures here for others. This morning, it was OBVIOUS that he only had ONE small question about a rare, technical issue.....NOT his inability to post pictures on the FordBarn. If there is one thing that I have learned about successfully fitting-in to this type of community, it is that whenever a subject comes up regarding something that I know little or nothing about, I usually just keep my mouth shut.
Like "51-Merc...." alluded to, there's a lot to be said about "difficult for you, easy for me". You were an attorney probably for eons. I personally cannot imagine sitting through 'law school', much less REMEMBERING most of what you learned toward that profession. Funny thing is that YOU (on SEVERAL occasions) have had to ask someone here to explain how to RE-SET your 'signature' line, not to mention how many times you have repeatedly asked how to empty your PM box......two procedures that couldn't possibly be any easier. I'm not knocking you for it.....just trying to point-out that some things come easily for folks, while others just have a hard time catching-on to the simplest of procedures. So with that, I am going to politely and sincerely beg you to quit suggesting that The Boss change this place up. DD
T5 W/TORQUE TUBE
Old 08-03-2021, 10:22 AM   #627
V8COOPMAN
V8COOPMAN's Avatar
VIDEO
"EARLY FORD PARTS STORE - San Dimas
https://www.youtube.com/watch?v=icTK5IJY7KE
- Phone Orders - Call (909) 305-1955
- Email - [email protected]
T5 W/TORQUE TUBE
Old 08-05-2021, 03:33 AM   #628
V8COOPMAN
V8COOPMAN's Avatar
Mods to FRENCH Block & Pan Vent
Use PRE-'49 Flywheel w/4" Crank!
T5 W/TORQUE TUBE
Old 08-05-2021, 06:15 PM   #629
V8COOPMAN
V8COOPMAN's Avatar
WATER Pump Bolt
T5 W/TORQUE TUBE
Old 08-06-2021, 02:41 AM   #630
V8COOPMAN
V8COOPMAN's Avatar
ENLARG & POST Pictures Narrative
https://www.fordbarn.com/forum/priva...m&pmid=1473964
T5 W/TORQUE TUBE
Old 08-11-2021, 07:43 PM   #631
V8COOPMAN
V8COOPMAN's Avatar
1935 & 1936 Spindle COMPARISON.
1935 on LEFT!
1935
1936
T5 W/TORQUE TUBE
Old 08-12-2021, 12:13 AM   #632
V8COOPMAN
V8COOPMAN's Avatar
1935/1936 Spindle Comparison
T5 W/TORQUE TUBE
Old 08-13-2021, 10:11 AM   #633
V8COOPMAN
V8COOPMAN's Avatar
Merc Riser Mount
T5 W/TORQUE TUBE
Old 08-13-2021, 05:59 PM   #634
V8COOPMAN
V8COOPMAN's Avatar
39 standard wiring
T5 W/TORQUE TUBE
Old 08-17-2021, 10:14 AM   #635
V8COOPMAN
V8COOPMAN's Avatar
Tank Pods
T5 W/TORQUE TUBE
Old 08-19-2021, 11:29 AM   #636
V8COOPMAN
V8COOPMAN's Avatar
EARLY '40 Perch Bolts WITH Sway Bar
'40 Perch Bolts - NO Sway Bar
LATER '40 Perch Bolts WITH LATE Sway Bar
EARLY '40 Sway Bar
LATE, Improved '40 Sway Bar
T5 W/TORQUE TUBE
Old 08-19-2021, 12:18 PM   #637
V8COOPMAN
V8COOPMAN's Avatar
T5 W/TORQUE TUBE
Old 08-22-2021, 06:58 PM   #638
V8COOPMAN
V8COOPMAN's Avatar
40 Clutch Release
T5 W/TORQUE TUBE
Old 08-25-2021, 10:38 AM   #639
V8COOPMAN
V8COOPMAN's Avatar
JIM'S 4-Speed
T5 W/TORQUE TUBE
Old 08-26-2021, 11:58 AM   #640
V8COOPMAN
V8COOPMAN's Avatar
Natural Rodent Control
T5 W/TORQUE TUBE
