Old 06-27-2021, 01:45 PM   #1
GAR64
Default 1947 Super Deluxe ignition Switch
Trying to diagnose an intermittent non start. Definitely a spark issue. I think the ignition switch may be bad. Removed it and having trouble opening it as I wanted to clean inside connections. Would replace it but all I find available is outer body with terminals. Anywhere I can get whole switch??
GAR64 is offline   Reply With Quote
Old 06-27-2021, 02:52 PM   #2
4dFord/SC
4dFord/SC's Avatar
Default Re: 1947 Super Deluxe ignition Switch
Check eBay, e.g., https://www.ebay.com/itm/17271948615...sAAOSwo0JWOqKB
4dFord/SC is offline   Reply With Quote
Old 06-27-2021, 03:33 PM   #3
Lawson Cox
Lawson Cox's Avatar
Originally Posted by 4dFord/SC View Post
I thought 47 still used the flip switch with locking steering column like was used for many years. Wasn't 48 the first year to not use that setup?
Old 06-27-2021, 03:52 PM   #4
1942deluxe
1942deluxe's Avatar
You are correct, Lawson.
Old 06-27-2021, 05:10 PM   #5
GAR64
Yes Lawson. I’m not looking for the key/cylinder. Square switch connects to toggle.
Old 06-27-2021, 10:24 PM   #6
fordor41
fordor41's Avatar
I removed mine from our my '41. removed the 2 screw that held it in, drilled out crimps, cleaned all contacts, taped it together at the flanges where screws pass thru with painters tape (just enough to hold it together, started the screws , pulled the tape off and finished tightening the screws.If the stationary contact is worn badly you usually can find them thru Ebay or vintage Ford parts dealers
fordor41 is offline   Reply With Quote
Old 06-27-2021, 10:45 PM   #7
GAR64
Thank you. Wasn’t obvious how to open it. I’ll drill out the mounting holes and open up and clean. Apparently you can’t get the whole unit anywhere.
Old 06-28-2021, 01:59 AM   #8
deuce lover
deuce lover's Avatar
Not difficult to find.Southside Obsolete in MN and ThirdGen Auto in TN should have NOS.
deuce lover is online now   Reply With Quote
Old 06-28-2021, 09:05 AM   #9
51woodie
51woodie's Avatar
I did the same as fordor41, on my '46 Coupe, except I soldered the "ears" on the outer edges, just enough to hold the case together. Make sure the lever and switch are in the correct position to mate, when you bolt the switch back on, as the pin from the lever has to mate into the hole in the back of the switch. Otherwise, the switch could get damaged.
51woodie is offline   Reply With Quote
Old 06-29-2021, 02:46 PM   #10
supereal
supereal's Avatar
The lever type ignition switch in the '47 commonly wears a groove in the bakelite in the back of the switch preventing the dimples in the internal arm from making contact. The parts are available from C&G (800-266-0470) Part# 81A-3704. If you need to replace the wiper arm, 81A-3704/9K (kit). The lever type switch was phased out in early '47. It had been a Ford item since '32 in one form or another.
supereal is offline   Reply With Quote
Old 07-01-2021, 04:46 AM   #11
GAR64
Opened the switch and cleaned all contacts. Re installed. Getting about 5.4 volts at coil with key on so apparently switch is functioning. Still no start. Seems like no spark. Resistance test on coil gives me 0.6 and 8400 ohms. Will have to get a helper to do spark test at plugs. Will very intermittently fire. Maybe points and condenser.
Old 07-01-2021, 01:22 PM   #12
GAR64
Well it seems I found the issue. Hi tension coil wire seems to have been spliced between coil and where it enters boot to connect to plug wires. I will replace it but wondering how the non coil end is removed from that rubber boot.
