Old 05-14-2021, 09:13 PM   #1
Steve Seidl
Steve Seidl's Avatar
Red face Placement of plug wires in rotor caps
Does someone have a diagram -sideview looking into each side of distributor- showing placement of plug wires into cap? I want to be correct fist time, no do overs. I have a persistent miss in motor trying to track down. Tanks in advance!! Steve
Steve Seidl is offline   Reply With Quote
Old 05-14-2021, 09:37 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Placement of plug wires in rotor caps
Does this help?
Old 05-14-2021, 10:39 PM   #3
koates
The brass high tension plug wire sockets are numbered in the plastic for either right or left cylinder bank plugs. You really cant get it wrong, can you? Regards, Kevin.
koates is offline   Reply With Quote
Old 05-14-2021, 11:06 PM   #4
Graham Freeman
Kevin,
Some of the aftermarket caps do not always have this feature.
Graham
Graham Freeman is offline   Reply With Quote
Old 05-14-2021, 11:22 PM   #5
koates
Originally Posted by Graham Freeman View Post
Kevin,
Graham
Yes but most all caps have the cylinders marked on them. Only cheap shit caps are not marked. Best not use them as some dimensions are also not correct. Regards, Kevin.
