Old 03-03-2021, 10:47 PM   #1
35fordtn
35fordtn's Avatar
Default Tech tip 覧 1940-48 transmission shifter arm repair
The last few weeks we致e had a few rebuilds on 40/48 shifter housings. The shifter arm pins are nearly always worn. Rather than replacing with diminishing NOS arms, we致e been repairing them for years, and thought I壇 share as it痴 simple. The below two photos show the common wear.
First grind the head of the original smooth and drive out with a punch. (Wear safety glasses)
Next drill the hole with a 19/64 drill bit.
Next drive in the new pin. And you are done!
We sell the replacement pins (see link below). I have gotten to where I replace them all as even compared to a NOS arm these pins fit the Clevis better for less shifter lever free play.. hope this helps someone save some $$ on a un-needed nos parts purchase.
https://thirdgenauto.com/product/194...m-repair-pins/
Old 03-04-2021, 03:45 AM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Tech tip 覧 1940-48 transmission shifter arm repair
OK, lets hear it, folks! THIRD GEN! THIRD GEN! THIRD GEN! THIRD GEN! THIRD GEN! THIRD GEN! DD
Third Gen Automotive
Phone: 844-327-5988
Url: thirdgenauto.com
2600 Old Nashville Hwy
McMinnville, TN 37110
Click Links Below __
T5 W/TORQUE TUBE
Old 03-04-2021, 06:35 AM   #3
Tim Ayers
Great tip and advice!
Old 03-04-2021, 08:31 AM   #4
corvette8n
corvette8n's Avatar
Cool, glad to know this option exists, Thanks.
Old 03-04-2021, 09:06 AM   #5
oldford2
oldford2's Avatar
What am I missing here? If you drive out the old shaft isn't the hole the correct size? Why do you have to drill it out?
Just curious
John
oldford2 is offline   Reply With Quote
Old 03-04-2021, 09:15 AM   #6
35fordtn
35fordtn's Avatar
The original pins are stepped down to act as a stop when installed at the factory... as in the originals are smaller in the portion that sits in the arm
Old 03-04-2021, 09:23 AM   #7
19Fordy
19Fordy's Avatar
An additional idea (to the above tip) is to replace the stock pins that attach shifter arms to transmission side cover with fine threaded nuts and bolts after you replace the seals.
Can be done with the transmission in the car. Clutch arm also. Still working great 20 years later. Zero play as all components are threaded. No pin peening required.
Old 03-04-2021, 10:02 AM   #8
Mart
Mart's Avatar
Nice job, Michael. I wondered about the drilling, now you've explained it, it all makes sense.
