#21 |
Yes, mine looks like the 39/40 Deluxe Coupe as you show, as long as it’s 31” long and 14 3/4” tall, which guessing it is,..Thank You
#22 |
Zeke3
Looked long and hard, this matches what I have, the plate with the two holes that hook to the decklid matches mine, and has a bend in the arm like mine. Mine is as wide ( plate with two holes ) and the plate angle is exactly the same. Says it’s for 41-48 Ford Tudor & Fordor Sedan & 1939-48 Mercury, so says C W Moss Thank You for your help Last edited by Bazooka Joe; 02-25-2021 at 12:18 PM. |
#23 |
Those are great photos mercurycyclone. Thank you for sharing. Nice to be able to see side to side comparisons.
Sometimes, ingenuity gets in the way of sense and sanity. |
#24 |
Will and Joe 38 Deluxe seems closer to 39 - 40 Deluxe and 38 Standard I think would be closer to 37 Ford Deluxe and Standard.
I have attached photos and measurements of 39 - 40 deluxe coupe. |
#25 |
I should have said I attached photos and measurements of the 39 and 40 Ford Deluxe & Standard Coupe door trim.
#26 | |
Mine is EXACTLY 31” long, not 31 3/4” wide as you reference for the 39-40 Ford Deluxe, and probably the Standards are also ( 31 3/4” long ) for those two years. Thinking Will D photo and measurements are more correct, but even then in his photo it still does not look exactly 31” long, as the tape measurement looks a tad off on both ends. Maybe not thou? He says that piece came off a 38 Deluxe Fordor, I’m sure it fits other years models also. Doubt it’s a one year specific model knock off. https://www.fordbarn.com/forum/attac...3&d=1613852381 I’m just trying to ID part for future sale. Thanks for everyone help,.. Last edited by Bazooka Joe; 02-25-2021 at 12:19 PM. |
#27 | |
#28 | |
Thanks again for your effort Joe |
