Old 02-19-2021, 08:18 PM   #1
36 ford vt
36 ford vt's Avatar
Default 36 Tudor wiper question
Hello Ford Barn Folks
I need some help on a couple questions on my 36 Tudor touring sedan windshield wipers -photo’s attached
The First question- Not sure how to remove the wiper arm from the shaft. I tried to remove the screw and it’s really stuck. Is removing this screw the way to remove the arm? I don’t want to break it if it’s not the way to remove the arm. Any input on removing the arm would be appreciated.
The second question. I Cant find a blade that fits the arm. The wiper motor is the original Trico vacuum, but I don’t think the arm is original based on the info in the 35-36 early ford v8 book and suppliers catalogs. The ones I have bought from the suppliers based on the year don’t fit correctly. I’d appreciate any info on what the arm is and what blade may be required
Thanks for any help on this
Ron
File Type: jpg 5B125C95-05B5-4D61-A3BD-D674675C6D5E.jpg (63.9 KB, 62 views)
36 ford vt is offline   Reply With Quote
Old 02-20-2021, 12:45 PM   #2
johndee138
johndee138's Avatar
Default Re: 36 Tudor wiper question
That doesn't look like a 36 wiper arm. could it have been replaced with a later style?
johndee138 is offline   Reply With Quote
Old 02-20-2021, 12:54 PM   #3
Gary in La.
Gary in La.'s Avatar
That type of arm with the screw usually has a small serrated plate underneath that tightens up on the serrated shaft when the screw is tightened. Probably needs some penetrating fluid shot up inside.
Gary in La. is offline   Reply With Quote
Old 02-20-2021, 06:08 PM   #4
36 ford vt
36 ford vt's Avatar
Thanks Johndee and Gary
Johndee, I think it’s a good possibility it is a later style. I’ve had the car since 1963 so maybe that’s a good idea to look at ford wiper arms from maybe the 40s and 50s to see if I can find a match.
Gary, that sounds like removing the screw is the way to remove the arm. I’ll try the penetrating fluid and see if that helps
Thanks for your help guys!
Old 02-20-2021, 06:40 PM   #5
Lawson Cox
Lawson Cox's Avatar
Try a pair of vice-grips on the screw.
Old 02-20-2021, 06:54 PM   #6
36 ford vt
36 ford vt's Avatar
That sounds like a good idea. I’ll give it a try. Probably do a weeks work of penetrant first. Thanks Lawson
Old 02-21-2021, 06:39 AM   #7
Terry,OH
Terry,OH's Avatar
I suggest if the screw comes our of the arm when loosened, before it comes out too much try light taps on the screw head since the screw may be holding a wedge device.
Old 02-21-2021, 06:50 AM   #8
36 ford vt
36 ford vt's Avatar
Thanks Terry, I’ll do a little tapping with my brass hammer as I work the screw. With the penetrant that may help loosen the wedge and screw also.
