I am new to this forum and studying to buy my first Model A. I am a "purist" and want to maintain a stock condition as much as possible.
I don't intend to obtain or restore top tier show car, but I want to stay true. Is there a way from the car VIN/"A" number to determine what the specs were out of the factory? Regards, Kim Nicholas |
From the little I know, the serial number is a sequential number only. No information can be decoded from it other than the date the engine was tested and accepted.
The Judging Standards and Restoration Guideline would be your best bet.
https://www.mafca.com/pub_standards.html The frame number will get you within a few months of when the car was produced then the Guidelines will show what was correct for that time period. |
If you are looking for original color and are doing any kind of disassembly, look for spots that were never taken apart before. My car (had a rough black re-paint) parts of the gas tank once out indicated Andalusite Blue.
didn't we also have a discussion that the copra drab/chicle drab colors we have used are actually inaccurate?
Copra/chicle seem to have been corrupted over the years to three variations: "brown", "greenish" and "greyish". Based on a couple original cars I've seen, the brown variant might be closest to original. I like the brown variant best. Believe that is the one considered closest for fine point. "your results may vary"
no more model As for now........
#7 | |
I'm sure other folks can offer additional suggestions, but the idea is to look at the body, think like a painter, and see what things would be easier to mask than to remove. Then remove them and see what's underneath. Obviously you're not going to do these to a seller's car but once you decide on one, anything is game. Mr. Moose's idea of laying on your back to look up at the front of the gas tank from inside is as good a non-invasive thing that you can do as any (hard area to get to during a repaint, but if the gas tank was removed it for a repaint will be the new color). You might also try looking at the bottoms of the doors to see if anything jumps out. Good luck, and let us know what you end up with! JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
Only thing I can add to what Jay-Jay said is ti look at back side of gas tank.
By "front of the gas tank" I meant the firewall side (towards the front of the vehicle), which is what I think 29closedcabguy meant as "back" side.
JayJay
I’ve never found much from a gas tank as they were painted in the car I believe
Getting behind previously unassembled areas works. Lightly sand door jambs but that does leave tracks if not going for full repaint As to chicle/copra..yes common current formula is wrong: way too green tint Saw a original car many years ago and it was much more taupe or faint brown tint. Green tint not there |
I removed the Briggs body tag from the firewall of a black 1931 de luxe phaeton to reveal Ford Maroon which was still glossy . This was on an export RHD car. I have removed data plates mostly to find black which I dont think was the original colour .Ford Maroon the identical shade was used by Ford in England into the early 2 thousands .
John in when will this lockdown ever end Suffolk County England . |
Original to THAT car, (look under something that is bolted on),
or original to what was correct for that model? The Judging Standards and Restoration Guidelines. |
#13 |
By all of this discussion, I assume the cars NEVER had a 'primer' coat?
Thanks |
#14 |
Not primed as we think today, but unpainted bodies were treated to a process called Bonderizing which provided a surface for paint to bond to.
#15 |
When I restored my 1932 Coupe, I found under the door panel some over spray of the original Washington Blue. What was really neat was that at assembly, a factory worker used a grease pencil and wrote "W Blue" inside door. It was kind of a "connection" back to the guy who painted my car. Ed
#16 |
Model A Paint and Color Guide, available from the National Clubs, DEFINES proper colors, no matter what might appear to be from various ways such as looking behind the gas tank.
"VIN" number just represents what SEQUENTIAL ENGINE NUMBER down the engine line that went into the car. Good Luck. |
#17 |
Kim, I sent you a PM, look in the upper right corner. Vern
#18 |
On my 29 cabriolet, I found body color in the creases of the A Pillar and behind the data plate. I recall also perhaps behind where the windshield opened. The color was Andalusite Blue, consistent with my father buying the car in late 1929, and a original b&W photograph that looked like the car was black. ...and my dad’s recollection of a dark blue color. I got it with the much damaged original paint in 1958-59, painted in 1963, and finally repainted it Andalucite blue post 2010.
#19 |
Can anyone help me with this paint formula question?
I have my brand, and paint formula that is on my car. Can someone help me identify the color, if I type it in here? I understand that this is working backwards from what we normally deal with... |
#20 | |
You might also look at this old list of paint codes and see if you can find something. If you don't have an original Model A color, go to your closest dealer for that brand auto paint and have them look up the color code (I presume that's what you meant when you said "paint formula") and they should be able to tell you what the paint was used on and what its name(s) were. JayJay
