Old 01-16-2021, 07:34 PM   #1
OldGold360
Default 1936 P/U Metalshaping
You all have been really great at answering the questions I have asked regarding my ‘36 pickup that I am building. So I thought I would share what I’m working on this weekend. On my cab, the back panel and roof of my pickup is rough. The damage to my back panel comes up higher than the replacement panels would cover so here is my process I used to build a replacement.
I started out by cutting out my panel and adding some compound shape to it with a sheetmetal power hammer that is only 5 years newer than the truck. I used a couple of body sweeps to check the shape to make sure it’s the same shape as the original. The power hammer does a great job of adding a low crown to the panel without leaving any hammer marks.
File Type: jpg 61E997F9-AC49-4EF2-9304-B56F91A0E02D.jpg (51.1 KB, 131 views)
OldGold360 is offline   Reply With Quote
Old 01-16-2021, 07:37 PM   #2
OldGold360
Default Re: 1936 P/U Metalshaping
Next I figured out the shape of the lower bead and used modern technology and 3D printed tooling to add the bead to the panel using a pullmax machine.
File Type: jpg 042DF97A-E35C-4CA5-8BB3-413A2D42363A.jpg (42.1 KB, 127 views)
File Type: jpg 0857805F-257C-4477-8A1A-10C7C88CD898.jpg (53.1 KB, 133 views)
Old 01-16-2021, 07:42 PM   #3
OldGold360
After bending the lower edge in the brake, I 3D printed the shape of the bead in the center to add to a simple hammer form I quickly made to bend the edge at the bump in the bead. I clamped to the table and turned the edge using mallets and corking tools.
There are many other ways to complete this process, but this is the way I did it and I am happy with the results. Thanks for looking.
Old 01-16-2021, 07:43 PM   #4
36and63
36and63's Avatar
Impressive metal working skills - Keep the updates coming on your project.
Pat
36and63 is offline   Reply With Quote
Old 01-16-2021, 08:10 PM   #5
deuce5wndw
deuce5wndw's Avatar
You are a very talented metal worker! Keep the progress reports coming!
Dale
deuce5wndw is offline   Reply With Quote
Old 01-16-2021, 08:36 PM   #6
Wehill99
Wehill99's Avatar
I just spent today working on the same section of my 36 truck!
Unfortunately my shop doesn’t have all the tools that yours does. I purchased the lower edge panel and welded in a large patch panel above mimicking what you have.
Your panel will be much easier to keep flat. I’ll send pictures when finished
Wehill99 is offline   Reply With Quote
Old 01-16-2021, 08:45 PM   #7
Heard
Heard's Avatar
Ok OldGold, you have the skills and tools I WISH I had. Fess up, I need a little bit about your background. You don't just go buy a power hammer and Pullmax and turn out stuff like this.
BTW....love the mid '30s pickups. I have a '35 I'm working on.
Heard
Do I look like I have a plan B?
Heard is offline   Reply With Quote
Old 01-16-2021, 09:30 PM   #8
Lawson Cox
Lawson Cox's Avatar
I'm fortunate that the rear of my cab was virtually pristine so all I had to do was sand it. I'm SO glad. I couldn't even do THAT now that I am in my 90th year and virtually useless. LOL
Old 01-16-2021, 11:15 PM   #9
Clem Clement
Clem Clement's Avatar
Lawson: You are very valuable to us all.
Clem
Old 01-17-2021, 11:31 AM   #10
OldGold360
Thanks for the kind words. I’ll post some updates as I progress.
Heard
Some people probably do, but it’s taken me over 20 years to not only find, but also afford the equipment that I have. I’ve been a full time metalshaper for over 21 years (half my life) and 16 of those years has been self employed. This ‘36 pickup is the first vintage vehicle project I’ve done for myself in 20 years. I figured it was time to build something for myself. Good luck with your ‘35.
Old 01-17-2021, 02:32 PM   #11
Zeke3
Zeke3's Avatar
Very nice, thanks for sharing your work with us.
Zeke3 is offline   Reply With Quote
Old 01-17-2021, 03:00 PM   #12
flatford8
flatford8's Avatar
Nice work!....I’ve got a ‘37 for the next project and I’m looking forward to your updates....thanks for taking the the time to post them......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 01-17-2021, 03:33 PM   #13
OldGold360
No problem. Just trying to pitch in around here.
Update: I fit and TIG welded the panel in place this morning. I have some planishing to do on and around the welds, but moving forward nonetheless. If you’re wondering... I did have the cab media blasted and, for the first time, applied Picklex 20 to the cab to prevent flash rust prior to primer. The rear panel of the cab had a strange reaction and almost looks rusted, but don’t worry... I did wire brush the weld seam prior to welding. I don’t know if this is normal for Picklex to do this, but I don’t like what it did. The rest of the cab turned out great. I figured I should use my own personal project as the guinea pig vs testing on a clients project.
File Type: jpg 2E706AC2-D2B9-4037-A862-7529BE87C698.jpg (38.0 KB, 149 views)
File Type: jpg BAB079B3-51B4-4101-A12A-71A8229A61EF.jpg (34.1 KB, 126 views)
Old 01-17-2021, 03:42 PM   #14
hotcoupe
hotcoupe's Avatar
Nice clean,accurate work. I'm impressed! Thanx for posting, are you a member @ "allmetalshaping".
Tom
Tom
hotcoupe is offline   Reply With Quote
Old 01-17-2021, 06:28 PM   #15
OldGold360
Tom
Tom
I am, though I am not active on there.
Old 01-17-2021, 11:07 PM   #16
Tinker
Tinker's Avatar
nice work!
Old 01-18-2021, 02:19 PM   #17
corvette8n
corvette8n's Avatar
Wow you are very talented, thanks for the pictures, interesting project.
Old 01-18-2021, 05:53 PM   #18
FlatheadTed
FlatheadTed's Avatar
Looks good .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 01-19-2021, 09:18 AM   #19
Frank Miller
Frank Miller's Avatar
I'm lucky to have a friend with a metal shaping shop. I hang out and build stuff at my leisure and in return have access to a bunch of tools. I've had the pleasure of meeting some great people as well.
www.proshaper.com
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 01-19-2021, 12:25 PM   #20
Frank Miller
Anyone interested in Wrays youutube channel
Www.youtube.com/c/proshaper
There is an English wheel video i made the frame for. I make a came in the latest shrinking disc video.
