Old 01-10-2021, 01:19 PM   #21
40larry
Default Re: 1941 ford pickup heater
Originally Posted by skidmarks View Post
Are either correct for the truck? I think the fancy one is like the one i had in a 41 car and the "more square" is truck or truck only?
The defroster nob on my heater, from what i found is supposed to be a 39 40 because its just a plain nob were the replacement one available should be larger with DEF on it
The small trumpet shaped defroster knob in photo above would be correct for your 1941 Ford truck heater also...... I doubt if you will ever find any new or reproduced ones. Your only chance would be to get one off of an original heater.
40larry is offline   Reply With Quote
Old 01-10-2021, 02:33 PM   #22
alanwoodieman
pull knob for defroster is just a plain sort of white/light tan in color with no lettering could not answer the question about switch panels
Old 01-15-2021, 12:43 PM   #23
skidmarks
skidmarks's Avatar
Aside from searching for the correct mounting bracket for the heater switch, both heater cores that i have are bad.
All the local radiator shops have gone out of business so it is now search for a new one or find some one that can recore the one i have.
skidmarks is offline   Reply With Quote
Old 01-15-2021, 02:00 PM   #24
36fordguy
Question on heater, I have a 36 pu with a stock water heater and 8CA 53 merc motor and 8RT water pumps. The input to the water heater I use the top outlet in the pass side of the moter The outlet of the heater goes to the 8RT pas side water pump. This side of the motor takes a long time to come up to temp and runs cooler then the diver side. (20 to 30 degress) Should I take the water inlet to the oposite side Driver side as the input to the heater to balance the flow 36fordguy
36fordguy is offline   Reply With Quote
Old 01-15-2021, 04:47 PM   #25
alanwoodieman
could you post a picture of your stock heater? would like to compare to some others
Old 01-15-2021, 06:06 PM   #26
skidmarks
skidmarks's Avatar
What year was a ford hot water heater first available? Everything i have read was late 1938 for the 1939 year?
Old 01-15-2021, 07:12 PM   #27
36fordguy
It's an after market RED HEAD brand water type std heater. Small water filled core with an electric fan blowing air thru the core
