Old 12-19-2020, 08:54 AM   #1
hotcoupe
hotcoupe's Avatar
Default Sun distributor tester
Sun distributor tester modifications, for those of you that have a Sun machine, click on the link for some interesting improvements.https://youtu.be/ORabuWpZuXI
Tom
P. S. Be sure to check out his other Sun machine videos. TW
hotcoupe is offline   Reply With Quote
Old 12-21-2020, 10:20 AM   #2
uncle buck
uncle buck's Avatar
Default Re: Sun distributor tester
Thanks Tom. I have found lots of good videos like that. I need to figure out how to get my condenser meter on my 504 to work. Paramount looks to offer lots of services , but I didn't see anything about the condenser meter. I don't know if it is worth fixing or not, but with the helmet condenser failure rate I would like to try it. Any ideas for that?
uncle buck is offline   Reply With Quote
Old 12-21-2020, 11:26 AM   #3
marko39
I had my cond. meter repaired at local audio shop. He replaced all the old capacitors and I got to test all my old Nors condensers found at swap meets years ago. Most failed but a new Napa one tested good. The old capacitors were just like old condensers.
marko39 is offline   Reply With Quote
