Old 12-21-2020, 06:49 AM   #1
rufus39
rufus39's Avatar
Default Rear End- Is it worth saving ?
I ran across this yesterday, wondering if the internals may be worth saving.. Someone made a trailer frame from this many years ago. Just curious what year(s) it applies to .
Thanks for your input.
rufus39 is offline   Reply With Quote
Old 12-21-2020, 07:03 AM   #2
Rodrelic
Default Re: Rear End- Is it worth saving ?
Model A I think by wishbones. Looks like it was a kit, hardware may be repurposed somewhere. Maybe a bench top stand to use when rebuilding a banjo rear end.
Wheels are keepers
Rodrelic is offline   Reply With Quote
Old 12-21-2020, 08:18 AM   #3
Charlie ny
Charlie ny
Old 12-21-2020, 02:02 PM   #4
rotorwrench
rotorwrench's Avatar
It has the model A spring over axle shackle mounts. If the axles & gears aren't all rusty then it may have some good parts. The axle bells make good shop stands if it's all corroded up.
Old 12-21-2020, 02:07 PM   #5
Charlie Stephens
The guts fit '32 (except late). The wheel rims are probably cracked from having been torqued down on Model A hubs without a spacer, check for cracks at the lug nut holes.
Charlie Stephens
Old 12-21-2020, 03:00 PM   #6
rufus39
rufus39's Avatar
Thanks Guys for the replies. .
I think I will get it & put in the pile to save .
