Old 12-15-2020, 03:07 PM   #1
Superhart
Superhart's Avatar
Default Coupe Window Replacement
I have a cracked rear window and left quarter window in my 1930 Coupe that I want to replace. Never done it before. Looking to the readership for info, suggestions, etc. before I attempt the operation. If anyone has done this, I would appreciate input. Thanks.
Superhart is offline   Reply With Quote
Old 12-15-2020, 03:20 PM   #2
29spcoupe
29spcoupe's Avatar
Default Re: Coupe Window Replacement
I replaced the quarter window in my '29. Just remove the panels that surround the window molding and then remove the screws that hold the molding in place. Take the window to a glass shop and have them duplicate the glass. I put electrical tape over the edge of the glass and then reversed the order to put everything back. Just don't over tighten the screws so you don't crack the new glass.
29spcoupe is offline   Reply With Quote
Old 12-15-2020, 03:47 PM   #3
Superhart
Superhart's Avatar
My interior is finished so I assume that the interior quarter upholstery panels must be removed to access the window trim panels which have a "nailing edge" around them. Does the glass just set in a channel or is there a rubber weatherstrip? I need to do the rear window also.
Old 12-15-2020, 06:35 PM   #4
Oldbluoval
Oldbluoval's Avatar
The big problem is the rubber gasket that it seats in
all I know of is straight and not molded
Therefore, in the radius, it puckers and does not form well
Old 12-16-2020, 09:04 AM   #5
Chris in WNC
Chris in WNC's Avatar
If your upholstery is reasonably new, it will not be too difficult.
Replaced the quarter windows on an unrestored '31 Coupe about 10-15 years ago and the fragile original fabric and backing board made it a very character-building experience....
no more model As for now........
Chris in WNC is offline   Reply With Quote
Old 12-18-2020, 10:06 AM   #6
KGBnut
KGBnut's Avatar
All the major suppliers sell some form of "Window Seal" or "Window Setting Rubber." You size it, cut it with a razor, and close the loop with super glue. I warm the seal up before stretching it, and make it just a little tighter than I think I want to. I've had good luck with it.
I also think that there are now preformed seals, but I have no experience with those.
Good luck,
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 12-18-2020, 03:59 PM   #7
Superhart
Superhart's Avatar
I believe I get the picture now. Just one more question: The "window setting rubber" is a U shaped gasket that fits around the glass piece. Does the window piece then merely sit in some sort of channel inside the outer body panel and held in place by the interior escutcheon panel?
Old 12-18-2020, 07:20 PM   #8
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Vintage glass in Tolland Ct. has all the factoty patterns and he will make individual pieces. Name is Todd
Barry B./ Ma. is offline   Reply With Quote
Old 12-21-2020, 06:24 PM   #9
KGBnut
KGBnut's Avatar
It has been a little while since I replaced that seal, but I seem to remember that there is an inner frame and the rubber is just squeezed between them.
Ken
Old 12-21-2020, 08:09 PM   #10
325w
The new glass and rubber just st up against rhe metal of the body. The window garnish holds it in place. You ca use some of the extra channel cut in strips to set the glass level.
325w is offline   Reply With Quote
