I want to replace the wiring in my 1950 sedan. I'll be keeping it stock with the 6 volt positive ground. For those who have done this, is it best to remove the dash to remove and install that part of the new harness, or will that open up a whole new can of worms?
I haven't worked on a 50 sedan but on a 46 Tudor removing the dash made rewiring much easier. There were still connections to be made on the firewall after reinstalling the dash but all doable. Removing the seat is a big help.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
Remove the dash. It will be easier in the long run. As well as some before pictures.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
Just removing the front seat helps a lot.
if you do decide to do it without removing dash a very good investment would be an LED light of some type.there are a myriad of different styles headband etc.until you try one you will be amazed a the light without the heat.let us know how you make out
