Old 12-09-2020, 06:38 PM   #1
STAN WHITE
Default Stromberg Carbs 81s 97s & 48s
I know a little about these Carbs. I had a good friend that asked me why I was USING 97S on multi carb setups. He only used 48s due to their larger size = more CFMs. I run three 48s with no progressive linkage, Works great for me. I would like to know what year ford started using the 97, and I have heard that the 48s were only used for one year. If this is true what year were the 48s used. I know that the 81s were used on the V8 60HP engines only I think that ended in 40 or 41. Thanks Stan White
STAN WHITE is offline   Reply With Quote
Old 12-09-2020, 06:55 PM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Stromberg Carbs 81s 97s & 48s
Ford started using the 97 in 1936 and the 48 in 1935
Old 12-09-2020, 06:56 PM   #3
scicala
scicala's Avatar
I'm not an authority on this, but I believe the 48 was used in '34, and the 97 from '35 thru '38. In 1939 ford switched to all Ford/Holley carburetors including the V8-60. The last V8-60 was 1940.
Sal
scicala is offline   Reply With Quote
Old 12-09-2020, 06:59 PM   #4
scicala
scicala's Avatar
Terry,OH,
I answered before I saw your reply. Wasn't the 48 used in '34 also ? Not sure.
Sal
Old 12-09-2020, 07:23 PM   #5
petehoovie
petehoovie's Avatar
Yes, the 48 was first used on the '34 model year....
Old 12-09-2020, 07:32 PM   #6
STAN WHITE
Thanks for the info, I had heard that the 48 was used on 34s but did not know for sure. I wonder why they went from 48s to 97s just curious. Does anyone know. I think that the 32 v8 ran a single barrel carb is this true. What did they run in 33? Thanks again. Stan
Old 12-09-2020, 08:09 PM   #7
1952henry
1952henry's Avatar
[QUOTE=STAN WHITE;1961295]Thanks for the info, I had heard that the 48 was used on 34s but did not know for sure. I wonder why they went from 48s to 97s just curious. Does anyone know. I think that the 32 v8 ran a single barrel carb is this true. What did they run in 33? Thanks again. Stan[/QUOTE
32-33 used a Detroit Lubricator. I believe the switch from 48s to 97s was for economy.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 12-09-2020, 08:10 PM   #8
petehoovie
petehoovie's Avatar
1932-1933 Ford Carburetor - Detroit Lubricator - Single Barrel
Old 12-09-2020, 10:01 PM   #9
STAN WHITE
PETE THANK YOU i DID NOT KNOW THAT. STAN
Old 12-10-2020, 09:47 AM   #10
nickthebandit
The picture of the Detroit Lubricator carburetor is for 1933. The 1932 model did not have the hand choke linkage on the passenger side.
nickthebandit is offline   Reply With Quote
Old 12-10-2020, 11:26 AM   #11
Gary in La.
Gary in La.'s Avatar
The 1940 V8-60 used a Holly model 92.
Gary in La. is offline   Reply With Quote
Old 12-10-2020, 12:07 PM   #12
Terry,OH
Terry,OH's Avatar
The Stromberg model 40 was used in 1934. It is nearly identical to the 48 without any model marking and just a couple internal changes. Ford did not start introduction of the new year models with new carburetors, but phased the new Carbs. in service so there is some carry over into the next year.
The 97 offered slightly better gas mileage over the 48 and a summer and winter adjustment.
Old 12-10-2020, 07:45 PM   #13
Pete
Ford would never have dreamed his 48 carbs would have been developed to this state.
These have been modified to float less and have enlarged venturi's
Old 12-11-2020, 01:51 AM   #14
frnkeore
frnkeore's Avatar
It is my understanding the the reason they are called "48" is that it comes from Fords part number for 1934.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 12-11-2020, 02:18 AM   #15
koates
Fords part number for 1934 is the prefix "40" and the prefix "48" is for 1935. The 97 carb was used in 1936. The 97 was for point 97 inches diameter of the venturi which made it slightly more economical than a 48 or a 40 carb. The 97 also had a two position accelerator rod position for winter and summer which had the potential to save fuel which the other two carbs did not have. Regards, Kevin.
koates is offline   Reply With Quote
Old 12-11-2020, 06:20 PM   #16
aussie merc
aussie merc's Avatar
single/ multi carb it doesn't matter the trick is to feed it not drown it most people dont relise but on a factory offered multi setup the carbs are actualy smaller than the single carb offering so the increase in cfm isn't that big
aussie merc is offline   Reply With Quote
